SuperHatch
    1987 Nissan Pathfinder V6 2door 4x4 5 Speed
    Skilled/Experienced Mechanic
    Rarely Go Off-Road
    Hawaii
SuperHatch's Achievements
  1. Redpath - sir, you are a life saver!! I was just poking around the engine just now and found that the MAF is also rigged up. Do you have the diagram for the MAF as well? Thanks so much for the help, I reeeeeally appreciate it!
  2. I have an 87 Pathfinder - V6 4x4 5 speed - doesn't run and the previous owner did a hack job on the Throttle Position Sensor wiring. The TPS has two connectors, a large one that has a white, black and red wire connected to it, that one is fine. But the other TPS only has two wires out of three wires connected, a blue one and pink one. It is missing a third wire. Questions: Does anyone have a schematic or know what the third wire color is and what it did? I.e. was the pink or blue wire the ground, the power or idle? Trying to get the wiring right so that I can get this thing started again. Thanks for any help you can provide!
