anperalta
    88 Pathfinder stock only 31 tires and more to come soon
    Limon, Costa rica
    Costa Rica
anperalta's Achievements
  1. I'll prefer to weld only the front diff
  2. Looks like the mechanic it's a little lost to.............. 3 days at the shop and still not found the problem........... is not spark, is not spark, fuel neither compression....... clogged injector? I really don't thing so!
  3. Well its already at the meca.... he will be inspected the egr valve....
  4. Yes i do change only the wire to.... and nothing... i also remove the valve cover to check for a stuck valve but all looks good to..... so im realy confused.....noob question....what is a basic leak down test??? Jeje any other idea will be appreciated.... saludos....
  5. I change the plug of #5 with the plug of # 4 cylinder and still have the misfire on #5....... turn 180º the distributor cap changing the post of #5 to #2 cylinder. .... and still misfire on #5.....
  6. Well hello everybody I'm a little new around here since December last year I got my Nissan and now i'm having a misfire problem on #5 cylinder which is making me going crazy........... already check spark, spark plugs, cap and rotor, and is not a fire problem, I don't think that can be a fuel problem because its an tbi injected and al the others 5 cylinders works good. Make a compression test only in that cylinder and shows 150 psi.......... pretty well, what else can I check for? I'm getting out of ideas and already have 22 days whit this problem...... HELP please!!!!
  7. but if you are getting a misfire problem first you got to know is which cylinder its failing because the popping in the throttle body could be an intake valve stuck..........
