tiredpathy
Everything posted by tiredpathy
The new crank sensor tests good, im really running out ideas on this one. any one know of something else that can cause all this headache? Any ideas or theorys would be great.
Fuses all check out ok and the wires as far as i can follow all seem to be ok. not sure where the wires from the ckp sensor go, i know one is ground and i get a 12 v sig from one when the key is on, and the third im suposed to get 5v when key is on and a metal object is touched to the end of the sensor. does that wire maybe go to pcm? could this be my problem with everything?
The only code is for fuel level sensor and thats been on for almost 2 years. the problem before was i had no radio, horn, alarm,security light, dome lights, power windows and locks would only work if key was in the "on" position and no start. running out of ideas i was curious if the horn itself worked so i unplugged it and touched a wire from the pos battery terminal to the horn, it honked and i noticed the security light was flashing again. checked everything again and all works except dome light.
No cap and rotor individual coil packs. what would make timing just go out?
Well i tested cam sensors and those were fine tested crank sensor and that failed, put a new crank sensor in and still wont start however if i unplug the sensor the truck starts and will run as long as i give it some gas. any ideas or help would be most appreciated! Thanks
ok all im back, since my last post i now have power back to my security and all other electronics work. however now im getting no spark. i put new plugs in and still nothing. i have a hard time believing that all six of my coil packs went at the same time but what do you guys think? anything else that i can check/test? im at a loss here!
does anyone know where the I.P.D.M ( intelligent power distribution module ) is? some leads I have followed point to a relay in that block. also how do you test relays with a multi meter ?
had security light before tho
i have no security light and when i plug in the code scanner there is no power at the obd port :-[
fuses are all good, and the truck wont start. turns over and gets fuel ( can smell it ) but acts as if the spark has been blocked. that mixed with all electronics not workin leads me to think alarm? also blinkers work but 4 ways dont, not sure if that helps any.
i have an 04 pathy, the battery was out for almost a month and when a new battery was put in i no longer have a radio, dash clock, horn, alarm and my power locks and windows only work if the key is in the ''on'' position. is the truck in some kind of lock out mode or is it something else? oh yea the truck wont start either. please help!!!!
anyone know anything about factory security on these rigs?
hello everyone in forum land, im new to the whole forum thing but not new to my pathy. i have an 04 ( bought new w/6 miles on clock) and now has 270,xxx miles and is starting to have issues :-(
