KRDOORMAN
    I have a 1994 4x4 XE 5-speed base model with 31X10.5 tires.
    Rarely Go Off-Road
    XE
    SOUTHERN CALIFORNIA
KRDOORMAN's Achievements
  1. I would like to lift my 94 Pathfinder and upgrade to a heavier grade spring size to carry more weight than the stock springs. My question is " What springs have you used to achieve this?" And " Off of what vehicle have you removed them?"
  2. Whats up everybody. How exactly do I remove the high pressure fitting at the pump?
  3. I was told by a shop mechanic that there was a fault in the fuel injectors system on my 94' 4x4 Pathfinder. He said one of the injectors was going out and needed replaciing. the problem is he couldnt tell me or didnt know exactly which one was bad. The way that I figure it is, Its either one that has easy access or one that is burried under the intake manifold. My question is, if its any three under the manifold are they difficult to remove and how do I test them. Do I need to remove the intake to remove the injectors. Does any body have any answers? Thanks KRDOORMAN
