unloveable75
Everything posted by unloveable75
  1. no i didnt smell anything, but its also affecting the way it starts though, how about if i remove the cig fuse?? would my pathy still function normal??
  2. i recently changed the cig fuse and the interior light fuse and the radio fuse and nothing, still no power from the car stereo and no interior light and no clock, is there anything that got shorted out??
  3. hi recently i was trying to test a light on my cigarette lighter and realized that it shorted out and long with it the stereo wont power on the interior light doesnt come on and also the clock on the dash board, but everything else works fine . i also check to see if i burnt out a fuse and all the fuses are good none are burnt out, is there some thing else i should check , its weird , please help
  4. Hi I seem to have some Idle problems with my 1993 pathfinder , when starting to warm up like when it normally does starts off normal as usual at around 1400 rpms and it drops down to normal 1000 or 1100 rpms then suddenly goes spikes up to around 1500 rpms and stays there for a while and when i press hard on the accelerator and it againdrops to normal then when i lightly step on it then it spikes up again and stays up again.. i changed a fuel line that was dried and cracked and checked for other leaks and it appears to be normal.. what could it be??
  5. oh ok kool ,, thank you so much guys my pathy is now getting better, still blows a tiny bit of smoke but its getting there thanx ,
  6. update.... so what i did was i burn some of it off and i put in some gas treatment and so far is starting to run ok, theres an occasional rattling, loss of power , and blowing white smoke, is that still normal?? do i keep putting gas treatment?? , and when am i gonna get back to normal??
  7. update.... so what i did was i burn some of it off and i put in some gas treatment and so far is starting to run ok, theres an occasional rattling, loss of power , and blowing white smoke, is that still normal?? do i keep putting gas treatment?? , and when am i gonna get back to normal??
  8. No I havent checked in the ecu codes, so far theres no increase in temperature nor check engine light .
  9. ok ,, so also the white smoke is due to the water in the gas???
  10. i havent said anything to the gas station, ,,,, you mean to just put some premium gas to burn out the water from the tank???
  11. oh ok so its not that much of a big problem , well sort of,, thanks i checked on thr antifreeze level and oil and its all normal so it is water in the tank , so i'm gonna let it burn off and put better gas , or can i put some sort of gas treatment????? please reply
  12. so is there a chance that it could burn off with more use?? or is there a fast solution to this problem??
  13. no i havent filled it all the way up, the diesle pumps were seperate from the gas pumps , im gonna check on the radiator, thank you ,, i hope everything comes out fine , if theres any other solution please let me know.
  14. today i was out doing some errands and my pathfinder was running very good without any problems and i saw that i was running low on gas so i stopped at a gas station put some gas once after fueling i took off and suddenly it was sputtering and losing power and was running pretty rough and i also saw that a little white smoke was blowing out of the exhaust , i checked on the oil ( after it cooled ofcourse ) and it looked fine , and also notice at taking in first gear the engine rattled a bit and it never did before,, what could have happend??? please help,
