MOhaire
Everything posted by MOhaire
  1. yes seen your gray pathy me and my son is doing like your just 4 in front his is black with spare on back you said you copy kfabs we did to but did you cut 8 1/2 degree on both side driver and passenger yo said you didnt have to put in camber bolt i tried to get all info for last weeks all i like is getting strut spacer passenger side better toe in cut 8 1/2 degree spacers been between flanges then tack together remove and weld out 100 percent just want to wow if you did same way or had same problem
  2. fab my own 4 inch drop from drawing found on site got all done with 8 1/2 degree worked good on driver side going to cut one on 12 degree on passenger side see if it will help from being so toed in used longer rear brake line from hardbody 4x4 almost 7 inches longer than original think it work fine built 4 inch perch spacers and used rancho f 250 shocks and fab panhard drop used steering from honda accord hope with 12 degree strut spacer for passenger side it will all come together
  3. are they any way to lengthen brake line in rear with an another nissan brake part or do i have to buy extended line
  4. got an 81/2 degree angle on pipe just look like wheel toed in bad
  5. sfd
    1. MOhaire
      MOhaire
      fab my own drop used 8 1/2 degree strut spacer worked good on drivers side going to cut passenger side on 12 degree and see if its not toed in as bad got a longer rear brake line off of hardbody 4x4
