4
ebayfish last won the day on February 12 2016
ebayfish had the most liked content!
About ebayfish
- Birthday 03/08/1983
1995 3.0 Xterra Tranny, 3+3 & 33s
30-35
XE
1995
Gender
Nashville, TN
Country
ebayfish's Achievements
NPORA Fulltime Resident (4/5)
27
Wiring around factory amps, now no sound
ebayfish replied to ebayfish's topic in 90-95 WD21 Pathfinders
.....And it decided to start working today...Must be a short or dead ground somewhere. -
FWIW, I have a set of pacesetter headers that I bought off a guy from Craigslist. He had a 2wd hardbody & he sold them to me because he said they wouldn't bolt on to his truck due to the torsion bars. That being said, I have a body lift on my pathfinder & I think it would be dang near impossible to install the headers on a pathy without a body lift. Even with the extra room, it was still a PITA.
A friend of mine has a 95 pathfinder. As with my 95, he wanted to wire around his factory amps. His front channels were occasionally cutting out as the amp was failing. Using the instructions from crutchfield, we rewired it. The result was no sound at all through the speakers, but the aftermarket head unit still powers up. I checked our wiring against my pathfinder, everything looks identical. I checked all audio fuses, including the one on the back of the head unit & all seem fine, I also found a better ground for the head unit. I have a similar head unit in one of my Dodge Ram, so I pulled the dash & installed the head unit out of the pathfinder to the Dodge's wiring harness and it played as it should. I didn't have a multimeter, so it's all trial & error.
Which is the starter relay? It's not the one I thought, right behind the battery on pass side.
I had a starter go out on my '95. I replaced it with a Beck Arney starter after sitting for a couple weeks. When I went to start it, the battery barely had the power to turn the engine. While in mid crank, the gear stopped turning the flywheel & began to free spin. When I turned the key off the starter was still spinning. I had to pull the negative battery cable to stop it. The battery tested bad & I replaced it, thinking the low voltage wasn't allowing the relay to open. After putting the new battery on, it cranked perfectly. I've started it a couple dozen times since with no problems, but last night it did the exact same thing again. After I pulled the negative, when I went to put the negative terminal back on, it arced repeatedly. After about 2 minutes of waiting, I placed the cable on the terminal with no spark & then it started normally once again. The igition wire dosent seem to be in contact with the hot at the starter. Anybody got any ideas or should I assume there is an issue internally in the starter?
The brakes are surprisingly in good condition, truck just never met soap or a garden hose. I ended up giving this to a guy I work with thats a little down on his luck & one day he'll pay me back. He forgot to top off antifreeze(just water) in his Grand Cherokee after it overheated. When it hit 6°, well, now it needs a new engine. Not all is lost, I've already scavanged his JGC front springs & I'm going to teach him how to change the timing belt & add a trans coooler.
I've got a few 4 doors, never had a 2 door. All my 4 doors have mirrors like this or chrome. Have you seen different?
Pathfinder 95 4x4 cranks but won't start
ebayfish replied to Alexdlz's topic in 90-95 WD21 Pathfinders
Have you checked the fusable links that connect to the positive battery cable? I had one with a poor connection that wouldn't turn on some of the accessories that wouldn't allow it to start. -
I though I'd share some rebuild pics of my new 9 tons.....yes, I said 9 tons. 2.5 ton Rockwells just aren't enough for my crawler. Too bad the pathy isn't up to the task of turning these planetaries
Probably the coolant sensor as stated, bu also check 02 sensor, had similar issues. I unplugged mine & it ran better(plug on passenger wheel well). Kept it like that until I got my new one.
First thing, check wiring at the MAF sensor. This little bugger is the #1 cause for issues on these trucks, ensure proper connection & wiggle the wires a little & see if anything changes.
Have you shot some staring fluid in to see what it does? Maybe your fuel filter is clogged, or could have an injector clogging. Make sure to check all the fuses & relays as well. -
I guess all add one more to my fleet. This poor unappreciated guy was the cheapest thing to sell at the auction today. $350 and he came home with me. Did fine on the 50 mile drive back, running 80 down the interstate. Not a spot of rust on the frame/undercarriage. 148,000 miles. Only needs a power steering pump & a little TLC.
Have you checked the connections at the MAF? Giggle the wires as well. -
I'Be been driving my *new* '92 some lately. The other day when I started it, the "anti-lock" light came on the dash. I turned the ignition off & then back on.....no more warning light. Tonight, several days & starts later, the same warning light came home. I drove it with the with the light on for about 20 min. After I got home, when I shut the car off, turned off headlights, etc., I stepped out to notice the brake lights still on. I pulled fuses to find its the stop lights, not tail lights. Is it safe to assume its a pressure sensor going bad/gummed up at the petal or are there any other common electrical gremlins that are common to do things such as that?
