algg
Everything posted by algg
  1. Hey I have a factory Manuals in electronic forms (PDF files) for 94-2000 Pathys is there a way to put them on the forums for people to download? Thanks, AL
  2. HI! AS I stated before I picked up another Pathy, (this is my third) and this one is auto trany unlike the other two. Long story, short reverse do not work, so I need help fixing it. Anybody have info? or advise? THANK YOU.
  3. Had similar problem. It was the timing, but not judt the T-belt. I had both head gasckets hanged, so had to take the dist out. When puting it back together kinda was rushing so did not put the dist in right. It could be that somebody had plaied with your dist in that first garage ( sounds like they don't know what they are doing anyway ) and screwed it up.
  4. Thanks for the link very helpful. But there are two connectors above the fuse box behind the dash plastic from 93 up. And you can plug it in to the reader. It is just easier I think. But for now I will try to use the info from the link. Thanks again 88. For some unknown reason one of the Path’s acting up. We actually did plug it to the reader at the shop and it showed up the speed sensor code (which I got out yesterday :furious: ) Put the other one in at for a wile it was driving fine w/out engine check light. Towards the end of the day the check engine light shows up again and it started to fill rough. So that is why I was asking about the soft and the connector cause the shop charges $50 for "computer diagnostic" :furious
  5. Hi! Guys! Question: does anybody have a diagnostic soft for Nissans? And if yes how to get it. and last is the connectors are available? Thanks.
  6. %^%^%^% CHANEL LOCKS!!!!! BIG ONES 2.5 H. ^%^%^ Lot of words #@%^ and scratches, but out. and now I need the correct new one cause the one I have is not @#@&*^* again. Thanks for your replys.
  7. Yes! I did that, but the thing is stack in there and does NOT want to come out. I use everything that I could find + sraied it with PB Bluster, and it still not movig. at the end the stupid little ear bracket brock off. *@# & *@#*@ Thanks any way.
  8. Hi everybody. First of all let me tell you, this is the most helpful forum for the Pathfinders. I did learned a lot from you guys. Thank you. Now to the little problem I have. I need to get the speed sensor out of the TC to replace it, and don’t know how. Any help? Thanks.
  9. Just had the same problem! I had two different belts which were supposetly for the Pathys, but one was not even had same numbers. So make sure the belt is the correct one.
