pittmanjustin
Everything posted by pittmanjustin
  1. so does anyone know if you can put a rubber expansion plug in it i tried today and when t got tight made few more lil turn and it popped out
  2. so does anyone know if you can put a rubber expansion plug in it i tried today and when t got tight made few more lil turn and it popped out
  3. iim sorry my daughter has messed up most of my buttons on my laptop
  4. i knew that but i thought i drained all the water from runnng t after drained the radiator
  5. yeah i had straght water in t cause the radiator has been leaking but i got a new one right before this happened but i dont understamd u it busted the plug had drained the water and the thermosat was out and i ran it for a min after ii draained rhe radaTOR
  6. i fpund the prombelm it blew a freeze plug on the top of the block i was gone for a week so i guess it did get that cold
  7. i fpund the prombelm it blew a freeze plug on the top of the block
  8. 95 pathy 3.0 4x4 i draned the water cauesed hadnt had a thermosat in it and didnt want it to freeze up well t never got to that temp down here now when i refilled it with water with engine off its off its pouring from the left sde of the themostat houseng i cant even flill the radiator fast enough
  9. yeah its auto and t dont change when wiggle the ignition. t has just been replaced sometimes it will start if i mash the brake so im thinkng interlock relay and starter relay or just put a push button on it would be simple someone has already had a switch right there where u would put a push start at but it has 255000 miles runs great its just my fishing n around town truck i have a titan for long trips but its 2wd and horribble gas mileage
  10. stll couldnt fimd the relay the motor and tranny was bought new and was put in by people like us lol there are wires umhooked everwhere but everything works can connect a wire to the solenoid and touch it to the battery and it turns everytime
  11. when i looked it up it runs through the ignition rekay and the ignition was replaced before i got it so ill just buy new relay they only 10 bucks
  12. because when t fell off it melted the wire and blew out the battery
  13. where is that relay i done bought new battery and wires after the old starter went bad
  14. i just replaced my starter on 95 pathy 4x4 auto cause the old one clicked forever then the housing broke and it fell off i went bought new starter from autozone cause oreilly was out of stock and few days later its clicking again but it wlll eventualy start and when it does it doesnt drag at all i replaced the wires too due to them ripping when the old one fell off. did i just get a crappy starter or is it my pathy causing it thanks for any help starter does have lifetime warranty but its not fun replacng lol
  15. 95 xe 4x4 253k still running strong just minor repairs
  16. i think the brake on the axle is just worn too bad truck has 253k with original hubs s
  17. stumped again my 4wd worked good for couple days and hub quit locking in but i can swap the hubs and they both work just the passenger side axle wont lock in and it was the driver side that was broke but both insides of hubs are good just cant figure out y passenger side axle wont lock in
  18. ok thanks i got it figured out i really appreciate it. its hard to find good help these days
  19. i could never get that link to work i got the page where its a list of pdfs
  20. i saw that there is sOME oil on the solenoid where the wires connect so my next step is to take wires off and clean it before spending and money on parts i may not need but the other battery was bad and it hasnt failed to start yet. knock on wood lol
  21. its an automatic i took the battery to parts house to get it checked cause they carry the brand and it was only 16 months old so i got new one for free now sometimes it cranks on 1st turn and sometimes it clicks a few times then cranks but i no longer need a jump when it clicks it usually only clicks once or twice then spins over fast with no dragging so is it the solenoid or maybe the relay
  22. i have 95 pathy 4x4 auto what is the factory cold cranking amps the battery that is in it is a 535 and i belive its too small
  23. i also have another dumb question when starting my starter will click like battery is dead sometimes it cranks on first try but after 3 clicks my battery is dead i can hook up my charger on boost and it starts on 1st try i just bought the truck the battery is just a year old with 535 cold crank is that big enough for it or do i need a bigger battery or is it the starter but when on boost the starter turns fast
  24. i finally got it fixed a piece of my old hub brake was stuck inside the brack on the axle i found it when i took everything off the cleaned it after greasin it and putting it back together it works like a champ locks in smooth and locks out smooth you can barely hear it click thanks for all the help i have tried other websites that popped up first when searching on google and this site is the only one that has replied back i will be on this one from now on and forget about the others
