oh, and for anyone that wanted to know specifics on what it took to make this happen.. ill list what i did.
-1984 300zx turbo / with BW T-5 tranny..
-swapped motor mounts from the original blown up v6, along with alternator, power steering pump.
-swapped from Z31 intake to 96 pathfinder plenum. (had to trim around the bolting location because i have top feed turbo fuel rails)
-used z31 throttle body, (had to make a small 3" plate for the throttle cable to relocate to opposite side of pathy tb throttle spot)
^^^ - because i was broke and only had 26$ for a stripped plenum...\
-bought 89 maxima distributer cap so coil wire was away from plenum (doesnt change timing at all)
- used a ka24 trans mount (only used 2 out of 4 bolts) to mount it to the truck .... no issues at all... did this because mine was an automatic se-v6 before.
- had to get a few inches taken out of the driveshaft - automatic yolk was correct spline count.
- used z31 ENGINE harness only, 5 speed ecu, nothing past the 16 pin connector near ecu.
- took the rest of 16 pin plug near ecu and cut a few inches from it, so it was easier to run wires where i needed them.
- pins 3, and 5 where extended to the original ecu spot under seat, and spliced into 3, and 5 there.
- pin 9 from the same plug is start signal wire, spliced to pin 9 under.
- pin 10 i wired to pin 10 (neutral safety) under the seat to keep the interlock so i can have a theft deterrent under my hood.... ( i live in the city so..... i dont want people trying to hotwire my @!*%... and get away with it )
- pin 34 runs to pin 34 for ignition power.
- for water temp gauge i just exetended factory wire under hood on trucks harness, so i could tuck the old harness back somewhere out of the way.
- deleted and tucked wiring for, air bypass, FICD, EGR, and Fuel Pressure solenoid.....
- kept fuel temp, head temp, maf, tps and cas. this is all my truck runs on and does fine.
- and FINALLY. the fusible link attatched to the z harness, gets ran to battery for constant power.
it took a little help and hints from KINGMAN, and studying the 84 FSM and 88 FSM for a month to make sure everything was correct for this swap to be possible..... hope this helps anyone thinking to do this in the future.... as i had been wanting to do this swap for 6 years before i made it happen.... total investment on my truck is about 800 which included buying the truck and the parts to make it where its at... not including all the z parts i had from my wrecked car. if any questions... PM me or simply post it up... i will post more vids and pics as they get done.
