valday33
Everything posted by valday33
  1. Проставка над стойкой имеет угол наклона 8,5 градусов? в какую сторону ставится наклон проставки? Как усилить крепление проставок, чтоб подрамник не шатался на плохой дороге? У знакомого, после установки комплекта подрамник имел движение влево-вправо. Он делал перемычку между задними. Возможно есть готовые решения? поднимать планирую на 4". Spacer over the counter has the angle of tilt of 8.5 degrees? in what direction is the slope of spacers? As to secure for the shims to a stretcher is not hanging out in a bad way? From a friend, after installation kit stretcher was moving to the left-to the right. He did a jumper between the rear. Perhaps there is a ready-made solution? lift plan to 4".
  2. Hello dear forum users. I'm from Russia in English are not speak and do not write, read with difficulty. Please forgive me for the tiny text. I am interested in the topic of lifting terrano (pathfinder) 50-th of the body. Going to increase the clearance of Nissan Elgrand. He has 100% compatibility of the running gear parts and fasteners stretcher with terrano. Plus to that is not documented gear in the transmission. I want to make followed by a minibus with a comfortable interior. Ask why not the Mitsubishi Delica? so the circumstances. In this topic a lot of photos with the details of the shims are opened. Could You re-post pictures in this topic? Thanks in advance!
