Is it serious that the Thorley header (THY-464-2) "Does not fit 5-speed models with Hydraulic Clutch"
http://www.dougthorleyheaders.com/details_...ProductID=14111
Folks, who installed it, what do you say? Don't you have hydraulic clutch (if M/T)?
Rusty4x4
This is a 92' SE pathy, FS5R30A MT. My back up lights are not working. The switch is OK. However the wireing of the backup light switch and the neutral sensor is just not matching with the service manual. It looks like that both switches are connected with a single wire to the harness while they are connected with each other with an other single wire. Meanwhile the neutral sensor gives 20 ohm regardless the shift position. Is this a normal or could be a fabrication of a previous owner of this car?
Rusty.
