Cryphix
Everything posted by Cryphix
  1. So I finally bought a replacement for my window motor and the only plug that is on the motor i connected with out putting it in just to test it) to the other side of the plug that is on my car. I turned my car on and nothing. The motor wouldn't go up or down, it just stayed there. Now the connection that goes from the car to the switch you used to make the window go up and down is missing i found out. If anybody knows what that's called then please let me know so i can get a new one. Anyways does anybody know what wrong with it? I asked that guy if it was a working motor and he said it was so... I guess i can trust him. Also I still think it could be that same connector that is missing on my back door switch, could be missing also on that same switch on the driver side. I don't want to take off the door pannel to find out though What I bought: http://www.ebay.com/itm/230441605371?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
  2. My window is stuck in the up position. Also I remove the glass and the motor and the metal guide thing that holds the wire?
  3. I need to replace my 1996 Pathy rear passenger window motor and I was wondering if someone had a schematic or a video that could help me with replacing it.
  4. I have a 96 pathy and my window motor is shot. So i want to go to the junkyard and get a new one, but all they have there is a 91 and a 95 pathy. I'm just wondering if anybody knows if those window motors would fit mine? Also both my rear and front windshield motors are out to so will a 91 or a 95 windshield washer motors fit mine also?
  5. I figured out where the pump is im just wondering how the hell i get the bumper off and stuff. Is there a good tutorial any where"?
  6. I was wondering how i would fix my wind shield washer sprayer? It has not worked for a while now and i'm wondering if there is a way to test it or where the motor and everything even is?
  7. I need to get one too, but i'm not going to till i lift it and do some other stuff to it.
  8. Down at the bottom of the car. Its those long plastic things under the front and rear doors that sick out a bit and you can step on.
  9. What are some semi cheap things to do to your pathy to make it look better/good. Also whats an SAS lift?
  10. LOL, ya i know i know, but i need some money
  11. I did it in like 30min, so it didn't take me to long. Also i didn't have it on a lift or anything so it was anoying having to lay on my back but whatever.
  12. Ok, but where do i put the tip of the tester at? LIke do i have to take apart the switch or something?
  13. I was wondering if there is an easy way to find out whats wrong with my rear passenger electric window. It is stuck in the up position and when i push the button it doesn't go down or move at all.
  14. Ok ill try and look for one of those, thanks again guys and ill let you know how my search goes
  15. Ok, i guess i mean like where is a good place to look for the best deals?
  16. I was wondering what type of exust should i get/ can i get to make my pathy sound louder and just all around better. Also what is a good brush guard for a 96 pathy?
  17. Thank you so much i got it working and it sounds so much better!! BTW I live in SC my brother made this and put ohio for some reason and i'm a he also
  18. Thanks so much for helping me and I will deffenitly check that out, and let you know if that fixes it
  19. Ever since i can remember i have had this rattling noise in my engine. It's only when i flor it or some times it does it randomly. I have done some research and everything i found people said it could be the timing chain, but i'm not sure. Also i have just started to get the squeeking noise when i slow down. I think it could be the breaks but again i'm not sure.
