Cryphix
I have a 96 Nissan pathfinder and i am wanting to do a lot to it :)
Screwdriver Mechanic
40-45
Do Not Go Off-Road
1996
cleveland
Country
Cryphix's Achievements
So I finally bought a replacement for my window motor and the only plug that is on the motor i connected with out putting it in just to test it) to the other side of the plug that is on my car. I turned my car on and nothing. The motor wouldn't go up or down, it just stayed there. Now the connection that goes from the car to the switch you used to make the window go up and down is missing i found out. If anybody knows what that's called then please let me know so i can get a new one. Anyways does anybody know what wrong with it? I asked that guy if it was a working motor and he said it was so... I guess i can trust him. Also I still think it could be that same connector that is missing on my back door switch, could be missing also on that same switch on the driver side. I don't want to take off the door pannel to find out though What I bought: http://www.ebay.com/itm/230441605371?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
My window is stuck in the up position. Also I remove the glass and the motor and the metal guide thing that holds the wire?
I need to replace my 1996 Pathy rear passenger window motor and I was wondering if someone had a schematic or a video that could help me with replacing it.
I have a 96 pathy and my window motor is shot. So i want to go to the junkyard and get a new one, but all they have there is a 91 and a 95 pathy. I'm just wondering if anybody knows if those window motors would fit mine? Also both my rear and front windshield motors are out to so will a 91 or a 95 windshield washer motors fit mine also?
I figured out where the pump is im just wondering how the hell i get the bumper off and stuff. Is there a good tutorial any where"?
I was wondering how i would fix my wind shield washer sprayer? It has not worked for a while now and i'm wondering if there is a way to test it or where the motor and everything even is?
I need to get one too, but i'm not going to till i lift it and do some other stuff to it.
Down at the bottom of the car. Its those long plastic things under the front and rear doors that sick out a bit and you can step on.
What are some semi cheap things to do to your pathy to make it look better/good. Also whats an SAS lift?
LOL, ya i know i know, but i need some money
I did it in like 30min, so it didn't take me to long. Also i didn't have it on a lift or anything so it was anoying having to lay on my back but whatever.
Help with fixing rear electric window?
Cryphix replied to Cryphix's topic in 96-2004 R50 Pathfinders
Ok, but where do i put the tip of the tester at? LIke do i have to take apart the switch or something? -
I was wondering if there is an easy way to find out whats wrong with my rear passenger electric window. It is stuck in the up position and when i push the button it doesn't go down or move at all.
Ok ill try and look for one of those, thanks again guys and ill let you know how my search goes
Ok, i guess i mean like where is a good place to look for the best deals?
