dannrathers
    platinum edition
    Do Not Go Off-Road
    NH
dannrathers's Achievements
  1. OK.. small problem here. I did this job and replaced all the gaskets and the thread in pvc valve. Well..put it back together and went to start it up.. It starts and then dies UNLESS i give it a bit of gas as it starts up. Then it runs normal. ANyone know the torq on the intake bolts? I did them by hand and made sure they were tight. I did not use any gasket maker..anyone think this would help? I did take everything apart again..then back together again and the same thing happens. ANY IDEAS? It's been about 1 month since last time I did it and I just have to tap the gas as it start up every time. This gets it running normal. Its been cold here and I haven't had the time to try it again with some gasket maker. I can only think its a vacuum leak..but it's weird that it runs ok after i tap the gas at start up.
