rrxx007
Everything posted by rrxx007
  1. Apparently mine is a 3.3l and it is in fact a timing belt but its still in good condition for a few miles !
  2. You're talking in respect to all the r50 models? Because correct me if I'm wrong, I think the 2002 models only came with a 3.5l v6
  3. I've been doing some research but all I've got is more confused. I have a 2002 pathfinder 2wd auto, in this truck is it a timing belt or a timing chain?? If its a belt Im planing on replacing it now along with the water pump and other components that will fail in the future so that I dont have to touch it again for some good time other than for normal maintenance. The odo is reading 97,000 and its my DD traveling some 20-30 miles daily and often stuck in rush-hour, plus the climate here is always hot and dusty.
  4. looking to buy one center cap for my r50 2001 model 6 spoke rim! Man I hate thiefs !
    1. Show previous comments  1 more
    2. rrxx007
      rrxx007
      mine too! I went into a sears for 5 min and boom one center cap gone!
    3. rwd5021
      rwd5021
      Yew thieves suck, but sorry no center caps to offer. Good luck searching, maybe make a thread in parts wanted section.
    4. rrxx007
      rrxx007
      thanks for the advice ! guess Im still a rookie to the forum hahahaha
  5. NGK spark plugs wire just arrived in the mail :D hopefully this will get her running perfectly
  6. well I already took the switch completely appart taking out each pin cleaning and then put it back together for nothing! bent them and made sure they made contact, nothing; moved around the plug, nothing; my makers and signal lights and brake lights all work only the low/high beam is giving me trouble
  7. I noticed the plug seems to have some corrosion too but how the heck can I clean those tiny little bastards?! btw thamks for the pic and support man
  8. Bad news! Just took the switch appart cleaned it with contact cleaner and a piece of sand paper and reinstalled to the truck and nothing now i'm doubtful as to what is the problem here...
  9. just removed the light switch, carefully though because the two parts between the wheel and the dash are about to crack. Anyway tried cleaning the contact pins with a piece of sanding paper and nothing, it seems that there is some corrosion but inside and bellow the copper colored pins i dont know if you can notice the greenish hue between the copper contacts. My question is can I remove that white part from the switch to clean it from the inside or should I just by a new one? BTW its a pathfinder xe 1994 4x4
