About jwblue
- Birthday 06/17/1971
1994 SE Black
Screwdriver Mechanic
Choose
Rarely Go Off-Road
1994
Gender
Huntington Beach, CA
Country
jwblue's Achievements
NPORA Veteran (3/5)
I got used to the OEM cup holders inside the center console. The trick is to use the left hand. With my right hand on the wheel, I would take the left hand and reach under my right arm and pull the drink under my arm.
Yes. Here is the OEM part. http://www.ebay.com/itm/NISSAN-PATH-G57NTX318-Factory-OEM-KEY-FOB-Keyless-Entry-Remote-Alarm-Replace-/370920560859?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1995%7CModel%3APathfinder&hash=item565c9698db&vxp=mtr
This is concerning a 2012 Kia Soul. I am posting here because I trust posters here more than at the Kia forums. I had been having all the maintenance on my vehicle done at a dealership. I decided to go to another shop that had a $159 special for lifetime alignments. I received a printout of my vehicles alignment. The printout had three numbers for each setting. I assume two of the numbers were a recommended setting and the third was the actual reading. Everything was within the recommended range except the following: Right Front Toe: -.25° > Recommended range (.10 to -.10) Front Total Toe: -.23° > Recommend range (-.20 to .20) Front Steer Ahead: > .13° - Recommended range (-.05 to .05) Did I need an alignment? The service person said I did but I am not sure.. After the alignment was done, the steering wheel seemed tight. Is this normal?
What does the XE stand for on 1991 Pathfinder model #
jwblue replied to Captain_Crazy's topic in General Forums
Another request to see the crank windows. -
I also could use something similar that gives the history of a vehicle.
Actually, thinking about it again, he probably can help me. Thanks. I will PM him.
Thank you but I would like my own copy.
I want a version that will have 1994 Pathfinder VINS.
My mother has a 2012 Kia Soul. Is there such a thing as an aftermarket part that will protect the gas tank from exploding in the case of a rear end collision? Who might sell something like this?
Difference between OEM brush guard and grill guard
jwblue replied to jwblue's topic in 90-95 WD21 Pathfinders
I think the factory ones were more round. -
1994 Pathfinder FSM doesn't include the security system?
jwblue replied to MrEviLDeD's topic in 90-95 WD21 Pathfinders
So none of those parts were installed by the factory? A lot of those parts were standard on the SE. The factory did not install them? -
Paint : What is the best way to repair a scratch and chipped paint?
jwblue replied to jwblue's topic in The Garage
Someone in another forum said the following: If I just use a paint pen with clear coat is there any risk of future rust damage? That is what I am concerned about. -
I was not clear. How many coats of paint? Do I need a primer? I read somewhere that if I see plastic it means I need primer. Below are pictures. https://plus.google.com/photos/110666213700006124028/albums/5848291055441517713/5848291052808896530?authkey=CITXgaLVpKnDew
