Cylvertip
    96 SE - 3.3 V6. 33x10.5's, Magna Flow exaust, K&N Air filter.
    Wet Side of Washington
Cylvertip's Achievements
  1. Ended up removing the air box resonator to get the fender liner far enough out of the way and also some very minor trimming on the lower front corner of the back flares. Only rub-age now is on the fuel line shroud in the passenger wheel well when at full lock - very minor contact. Pics show: After all complete; Full compression passenger rear, and finally prior to upgrades with 31's.
  2. Thanks for the info. I took your lead and just put 33x10.5 BFG's under my 96. Had 31x10.5 previously. I added one inch wheel spacers to get out from under the strut bucket, and then ended up adding a 1" strut spacer from NX4 to stop rubbing on the top of the fender well. I will get pics up in the next week or so. A little rub-age on the plastic fender liner - similar to pics you had. I will take a heat gun to those this weekend I think. No issue with power as stated. And yeah, I think your a little better than half a foot off the ground in that one pic..... Thanks again.
