xxrjxx
    96 3.3 5 spd
    bc
    Canada
xxrjxx's Achievements
  1. yes i tried a variety of different ways turning the key on and off, nothing worked...tried waiting after it wouldnt start, waited up to 15 - 20 min, cranks awsome u can easily tell that is is def spark or fuel related
  2. just pop it off then back on wait like 10 or 20 sec, no code reader, might have to take it into a buddys shop, thought there just might be a common prob like this that was known, i know that when the snow comes i dont wanna be relying on disconecting the battery every time it dosent start, its weird tho cause for like a week after i got it, never did it once, now all of a sudden its doing it like everytime i turn it off, so i guess it seems to come and go
  3. no luck on the replacement ecu, anyone else with any ideas?
  4. i guess its worth a shot, but honestly in 10 yrs of selling used car truck and suv parts i dont recall one time i have ever sold or been asked for a ecu from a pathfinder, not sayin that its not or possibly could be the ecu, but seems like a reach, but easy try none the less
  5. i know from experience in the old integras and civic they had a main relay that did just this, and the relay controlled the spark and fuel.. not sure if the pathfinder has something similar to this or not..
  6. I have a 96 pathy 5 speed, once and while ill go to try and start it up but it just cranks dosent fire, if i disconnect the battery for a couple mins the put it back on it will start right up...any ideas? guy i bought it from swore it needed a fuel pump, but i dont beileive this is fuel pump related if disconnecting the battery will make it start? seems to be elctrical, some kind of relay that controls either spark or fuel and disconnecting the battery some how resets it, any one know anything about this? thanks in advance!
  7. all the ball joints and sway bar links look good, cv's look good, only thing i cant really see is the lower control arm bushings and the trailing arm bushings..by strut tower mounts do u mean the shock tower themselves or the struts themselves? guess u cant tell till u take them out?
  8. clunky on bumps and pretty much whenever im not on flat ground, sound from front and rear, i know these have problems with bushngs, where should i start? lca's and trailing arms? shocks/struts? thanks
