1999R50
About 1999R50
  • Birthday 09/11/1988
    96 Terrano 31's that almost rub 99 Chilkoot with 33's that don't rub
    Terrano R3mR
    Barrie, Ontario
    Canada
  • Interests
    Metal Working
    Strength Training
    Raising animals
    Brewing Beer
    R50
6,749 profile views
1999R50's Achievements
NPORA Regular (2/5)
  1. Why not just buy my 96 Terrano with QD32Eti and then do a LHD conversion. I brought it over from Japan a few years ago but I need something 7 seater now. http://ontario.kijiji.ca/c-cars-vehicles-cars-trucks-Nissan-Terrano-W0QQAdIdZ452476051
  2. Well the fix didn't last. I just replaced it with one from NZ. It was only $150 shipped.
  3. So the tach on my Terrano has been not working properly since I got it here 6 months ago. It would work but be a bit higher then it should, and then fly all the way to red line and then not work at all, all in a matter of 15 seconds. I wasn't concerned because its automatic and running fine. I decided to try and fix it. I took out the tach, 2 screws up the top of the cluster and then 4 to remove the whole assembly. Once it is loose you will see the 4 screws that hold on the tach. One of the top ones is on a connection line that says GND next to it. This screw was not giving a good ground connection to the cluster. I loosed it and played with it while the truck was running and I could see the tach start working and then stop as I moved it. I ended up pushing it to one side and slowly tightening it. My tach is now working normally.
  4. Buy my Terrano http://barrie.kijiji.ca/c-cars-vehicles-cars-trucks-Nissan-Terrano-Diesel-W0QQAdIdZ386170862
  5. If I sold a set I would have to charge $250.
  6. The Nissan Safari
  7. I imported a 96 Terrano with the QD32Eti engine. It runs great, lots of torque, but shes looking a bit low for my liking. I found on here that the engine mounts are suppose to be the same as the VG33E. I can assure you that they are NOT. I sfd'd my Pathy and I know what the motor mounts are like on it. The spacing for the VG bolt pattern is around 1.5". On the QD they are closer to 3" spacing. Does anyone know where I can find a SFD for the QD? Mud Jayson doesn't seem to want to get back to me...
  8. Got my new 96 Terrano on the road... in Ontario
  9. http://www.omix-ada.com/gear-ratio-vs-tire-size.asp Check it out.
  10. Those are just 31's. I have 33x10.5 BFG A/T's in the garage waiting to go on.
  11. I wouldn't start hacking at your fenders. What I would do is jack up the one side and when the tire is 1/4" from the fender measure to see how big of a bump stop you will need. I know it will reduce the flex, but It will definitely be nicer, unless you are amazing at doing reconstructive body work. Just my opinion...
  12. So after being inspired by people on this site, I decided to make myself a SFD. Thanks to the info available I had all the block dimensions without even pulling a bolt out. The strut spacer geometry was the only tricky part. I actually only spaced the struts 2.125" and the sub frame the full 2.5. This way it brings my cv angle back closer to stock. Here are the strut spacers I believe the angles were 12 degrees and 5 degrees and you can't just simply add them together and divide by two to find the created angle at 45 degrees to the normal axis. If you draw it on a 3D softare you will see that it is closer to 12.5 degrees. I just wire EDM cut the pipe to exactly 12 and 5 so i didn't need to find the angle at 45. Welding them in orentation to the flanges was the confusing part, but I got it and they worked great! My chamber angle is perfect. The steering was a problem. I started with just a block to bridge the gap. Bad idea. It was terrible. My steering was screwed up before which I found out while doing the SFD that the U joint was siezed. So after arm wrestling my steering wheel for a couple days, I took out the block and bolted and welding in a second U joint. It works perfect now. For the rear I used F250 shocks and made some coil spacers from some pipe. Before with OME HD's front fender height of 35.5" and rear 36.5 After front fender height 37 3/4 and rear 39"
  13. 2 1/2" SFD Done!
    1. 01silvapathy
    2. 1999R50
      1999R50
      Not yet, I still have that "Cali Lean" and therefore need to lift the back.
  14. I power steering is in and out. I can't seem to figure out what it is. It work some times(not very often) but most of the time turing feels like an arm wrestle. When I pop the hood and turn the wheel while listening, I can hear the pump going. Maybe I just need a new pump.
