Well from what i read in the frequently asked questions section I learned that my dead fuel and temp guages were almost definitely a result of a faulty voltage regulator. So i pulled out my dash cluster and had a look around. The voltage regulator (here forth referred to as VR) was pretty easy to spot, it's located in the top right corner when you turn the dash cluster around and are looking from the back. I gave it a quick test with my multimeter (black to negative of a new 9 volt battery, yellow to positive, blue to positive test lead of multimeter, and negative test lead to negative of battery) I found that the little bugger was only giving me about 3.5 volts, having followed the traces on the back of the cluster and finding out I need 8 volts going to the gauges, this VR is shot for sure. For reference the black wire is ground, blue is Vout (voltage out), and yellow is Vin (voltage in). With that I headed over to radioshack. As I'm perusing the component parts section I discover they only carry 5VDC VRs and 12VDC VRs. However given further investigation i notice they also have adjustable VRs. Great, so it's definitely do-able i'm just going to need a few extra parts. I end up getting the adjustable VR, a pack of 5 100 ohm 1/2 watt resisters (only need one), and a 1K ohm trimmer (basically an adjustable resistor up to 1k ohms), I also pick up a little 2"x2" PCB to put everything on. Now in order to get the VR to 8VDC I'm going to need to wire the 100 ohm from the adjust leg of the VR to the Vout leg, and the trimmer from the adjust leg to ground. The trimmer needs to be set at 540 ohms in order for the VR to put out 8 volts. Another important thing to note is that the trimmer has 3 legs, one of which is called the wiper (the back of the bag it came in will tell you which leg it is). The wiper needs to be shorted to one of the other two legs, it doesn't really matter which, and from then out it will act like a regular resistor except now it's adjustable. I wired that all up on the PCB and connected it back to the cluster, being sure each wire went to it's appropriate place, and popped the whole thing back in the pathy. Grab my keys and turn her on, and all of a sudden my fuel gauge springs to life! Turns out I got a little over half a tank. As i let her run and warm up, my temp gauge slowly starts to rise as well! Cool all fixed, on to bigger and better things. Like figuring out why she idles so high and sporadically after she does get warmed up.
