About jprater88
- Birthday 10/11/1988
87 WD21 Red with gray interior, completely stolk for now
Skilled/Experienced Mechanic
16-21
Serious Off Road Enthusiast
1987
Contact Methods
Yahoo
xx_treva_xx@yahoo.com
Gender
Laramie Wyoming
jprater88's Achievements
Hey stevo I was going to ask you in your 4link thread if you ever got final word on axle we were talking about... I will soon be in a position to purchase it if everything is to my liking... What i need to know for one is price, track width, and if you will be offering a complete axle assembly or just the housing
Well didn't know that about the H223B, And I wasnt planning on putting a Dana 60 in the front I was planning on putting a Dana 44 with Dana 60 outer Knuckles not only for the strength but for the use of high steering arms. And I wasn't just wanting to get rid of the R200 because of the engine that I will eventually be putting in there. I am wanting to make a more serious trail rig and for what I will be putting it through IFS wont do.
I have opted to turn the pathy into almost a trail dedicated rig, but retaining street use. So I have thrown my IFS suspension upgrade in the trash because I already have 2 dailies and dont really need another one. I am starting to get all the parts for the start of my SAS swap and was debating if I should use DANA 60 outers on a DANA 44 axle for peace of mind, because I dont want to run into regretting my choice in the end. Now I am basically running my entire build off of Nissannuts's spread sheet on his build. And I am taking alot of what he did and goin to try duplicate it because it is just a work of beauty... There are other questions that I have about which DANA 44 is the closest track width to the pathy becuase I am going to be swapping the rear as well and would like to pull them from the same vehicle. I have searched the forums and seen that most people have opted to use the late 80's- early 90's waggoneer 44's but is that the one that is the closest? I know that the factory rear is more than enough for the size tire that I am wanting to run which are 35's but I am eventually goin to be swapping in a smallblock and I know that it cant possible handle the power that it will be producing which is close to about 450hp and around the same amount of torque. So If anyone could help with the questions that I have it would be much apprieciated, also any insite as to the DANA 60 outers and if they are neccicary... Thank you Joshua
I have a question I am considering doing a SAS soon and want to know other than the Wagoneer dana 44 is there any other 44 from other jeeps like the wrangler or anything that is the same size or slighly smaller/larger that I could use and not really widen my track width on my pathy... The reason i posted here is I like this build and Nut seems like he has a great erray of knowledge on this subject... Plus I like the fact he gave a build sheet on parts and a general write-up on it
or the ever so famous "did you check your blinker fluid lately your turn signals seem dim"
im lucky to even see 75, to tell the truth with the gearing in the older models (well my year atleast) they wont get up to fast or to a high speed... If they had an overdrive unit or another gearset inside the main cluster of the trans they might respond better and travel faster... I have been trying to find a different trans that will mate up and get better fuel economy
wow i feel like an idiot now thanks nunya you have been a big help
thanks nunya thats would help alot i want to get atleast my pc in so i can go further off road and more remote trails
how do i get the vents out to get to them and thanks for the info about the other two
Okay i have gotten a few mic. off-road toys(overland navigator for pc from spatial minds, and a unidin 510xl cb) that I want to put in and they all require a power source... I want to run them in parallel with the cigarette /12v power outlet but for some stupid reason I cant get the damn center con bezel off.. I found the two lower screws and the one hidden in the ash tray area now where else is it attached and how the hell do i get it off (sorry for the language its just irritating) so does anyone know how to get it off.. plus i need to fix an issue with how the previous owner put in the radio.. please help
