About TexasPthFnder95
- Birthday 11/29/1992
1995 XE V6 4x4, 2in lift, 31-10.5-15 AT's, aftermarket alloy wheels, sway-away t-bars, custom front bumper, off-road lights, camo interior, high flow air-filter, Flowmaster exhaust system, blue accent interior lights.
16-21
XE
1995
Gender
Texas
TexasPthFnder95's Achievements
NPORA Regular (2/5)
Bad Transmission Problems
TexasPthFnder95 replied to TexasPthFnder95's topic in 90-95 WD21 Pathfinders
fluid levels fine i can disconnect the battery long enough to reset the TCM and it drives fine until it enters Failsafe again -
Ok so last week one of the tranny lines on my 95 pathfinder 4x4 broke it lost 5 quarts of fluid i pulled over right away nothing was acting out of normal. I took it to the shop fixed the lines and refilled it now the torque converter seems to randomly jerk and shudder when coming to a stop and the vehicle will randomly stick in 3rd gear and will not upshift or downshift but it will only do it maybe once or twice every few days... So im thinking electrical cause the Fail-Safe light flashes at start up any advice would be greatly appriecated im not looking forward to spending another $2,800 on a tranny
I got the springs But i was reading your suppossed to cut part of the pigtail off does anyone no how much and what i need to do with Sway-Away T-bars to match up the front lift height with the rear
Alright im gonna get a set of V8 Cherokee springs but about how much to they lift and will my sway away T-bars be able to almost match the lift??
What about the doughnut style coil spring spacers that go in between the coil and the mount? Are there any ones that fit our rigs?
Thanks I already have the sway away torsion bars for 2yrs I love them! Thats why im getting new rear coils because spacing the stock ones to keep up with the cranked bars are putting my coils in severe strain i sheared off a spacer wheeling in sounded like a firecracker going off when it snapped so its defintly time to do the rear lift right
I've been looking into lifting my truck a little more than it is and i need to change the rear coil springs. Which ones would be the best for 2-3in of lift?
Rough Idle, Shaking, And Check Engine Light
Well i went and had a dianosis done on it and it turned out to be the EGR valve. Now im wondering should i clean this one or pay the $130 for the new one They said it could be an electrical problem or it could be clogged/stuck open -
I've been patching my front and rear main seals with stop leak for months now im ready to just do the complete repair timing belt water pump front and rear main seals everything. Has anyone tackled the front and rear main seal job yet? Repair time estimations or some hints on doing it
Mine was the 51 injector circut i changed the battery ground and connections and put fuel injector cleaner and octane booster haven't had problems with it again... I hope its good to go and it was just a random malfunction -
Thanks for the help but where can i get the chart? -
I havent checked it yet it just started doing this today. And do you mean checking it with a scanner? Or is there another way, sorry ive never had engine troubles before but its probaly something to expect at 231,000mi -
TexasPthFnder95 posted a topic in 90-95 WD21 Pathfinders
Ok so today my truck started shaking severly at start up and had a very rough idle and the check engine light would light up the after about 15 seconds it would clear up light would go off and truck would be normal I really need some help with this its got me stumped i even changed the battery ground because it was almost corroded in half (the wire) i thought it could have something to do with it but apparently not... -
leaking oil after oil change 95 3L v6
TexasPthFnder95 replied to Eviltwin's topic in 90-95 WD21 Pathfinders
How many miles are on your truck? Are you using a different weight oil or different filter? Maybe it could be a front or rear main seal or timing belt cam seal? Just throwing check points out there -
Thanks for all the help guys Im waiting till the week of thanks giving so i have no school to tackle it though im gonna do the gas tank tire carrier and cruise control all in the same week so i need the full weeks time
