Ok, I have searched and searched, but have not found any specific build threads that answer my questions specifically. After reading/researching the expense required to re-gear and lock the rear axle, along with the trouble of finding ring & pinions that will match the front axle. I already have a front Dana 30, 4.56 gears and a Detriot Truetrac locker that I will install into the axle. A common rear axle swap for Cherokee's is a Ford 8.8, as the ones from Explorers (not Rangers) come with 31-spline axle shafts, have super strong tubes, a huge 8.8-inch ring gear, disk brakes, 1/2 narrower width (same as the Pathy) and the same 5 on 4.5 bolt pattern as the Cherokee axle. I found one for $175 that I am going to pick up this weekend. I already have a set of 4.56 gears for the 8.8 (I originally installed 4.56 gears and ARB's front and rear on the Cherokee, but the gear charts are VERY wrong and I am now installing 4.88's (I would install 5.13's if they were available for the D-30, but they're not).
I also read that the JGC front springs will provide 3-inches of lift in the rear of the Pathy.
Now for the questions:
What suspensions have most of you used for the front SAS? I went to the Calmini site and see that they sell a cross-member with spring shackle attachment points and a kit with rear attachment points. Do you run leafs, and if so, what vehicle leafs work best and provide the same 3-inch lift as the rear? Do you run it shackle forward or shackle reversed? What do you do about the OE front cross-member, as it looks like it will contact the front DS during droop?
If you link the front, is there a kit available to use? What about the sway bars? On my Cherokee, I removed the rear sway bars and use JCR Quicker Disconnects to disco the front swaybar while wheeling, and attach it while on the highway. It works great and there is no sway even with the rear swaybar removed. I plan to do the same on the Pathy, but would be interested to know your experiences, etc.
What T-case does the Pathy have and is there a SYE available for it and is it necessary? Since I have to weld the spring buckets and link mounts onto the 8.8, I plan on repositioning the axle angle to adjust for the lift, so I don't think I will need adjustable control arms right away (maybe later, just to beef things up, but money is a factor right now, so I have to plan my expenses carefully and pick my battles).
The vehicle is currently at stock ride height and is on 31's. It looks like a 3-inch lift would be perfect for the 31's. I am planning on running 33's, so I expect to use a 3-inch body lift as many people have done to get the right clearance. It also looks like I will need to clearance the fenders fore and aft a bit, although they don't look like they will need to be cearanced upward.
In the end the vehicle will end up with some trimming, a 3-inch lift suspension lift, 3-inch body lift, a locked Dana-30 front with 4.56 gears, a locked rear Ford 8.8 with 4.56 gears and wearing 33-inch shoes. A budget paint job to clean up the ridiculous clear coat peel and a Currie, chromoly, high-steer set-up with one side flipped, some homemade bumpers and rock sliders and a roof rack, and this baby should be both beautiful and VERY trail capable.
I would greatly appreciate your opinions and advice based on good/bad experience. I will be at the junkyard pulling the Ford 8.8 this weekend and while I am looking for JGC springs, I might as well look for the right leaf springs and any other parts that make good components.
Thanks!
KJ
