1996 Nissan Pathfinder LE 4x4
Screwdriver Mechanic
30-35
Rarely Go Off-Road
1996
St. Louis
WATYF's Achievements
OK. This is my first 4x4, so all of this is news to me. And yes, it was only when turning fairly sharply. The only reason I even had 4H engaged on pavement was because I tried to quickly pull out of a parking lot on to a busy road when it was raining and the truck just slid all freaking over the place, so I thought 4WD would help with that. Before that, the only time I even turned 4WD on was on my land (definitely an off-road terrain). I guess I won't be turning it on in the city any more. I only use this vehicle for trips out to my land, so there's no need for it to be in 4WD on pavement. I just wanted to make sure that there wasn't something wrong with my suspension or drive-train, 'cause that would suck. WATYF
I will check for the orange sticker. And yes, I only noticed this on pavement. I was under the impression that you could use 4H for everyday driving (snow/rain/etc), which would involve pavement, obviously. Is this not the case? WATYF
I'm not quite sure how to describe this problem. Just wondering if anyone else has heard of/experienced anything like this. When I put my 96 LE in 4H and turn while driving slowly, my rear tires "skip". It's almost as if they're not turning at the same speed as the front tires (or at all) and they're just getting dragged along for the ride. At least, this is what is sounds like and feels like... I have yet to have someone else drive it so I can stand outside and see exactly what's going on. It only seems to happen when I'm turning, though, so maybe rotation speed isn't the issue. I really don't understand what would be causing this. Anyone else run into this problem? WATYF
Sweet! Thanks a ton, man. WATYF
Cool man. I appreciate that. WATYF
Yeah... I was hoping they'd be the same, but I asked the dude in the Nissan Parts thread and he said the info specified that it didn't fit earlier models. I don't wanna take a chance if I have to order it online. Maybe if I can find it locally I can try it out and just return it if it doesn't fit. WATYF
Thanks, I will do that. WATYF
Sorry... I forgot to mention. Mine is a '96. It looks like that part is for 2001-2004. Did they make the same for '96? WATYF
Can anyone recommend a good cargo liner for an R50? I'd like to find one that will cover the entire cargo area with the seats down, but I'm having trouble finding one. WATYF
Tow Hitches And Spare Tire Mounting Locations...
WATYF replied to WATYF's topic in 96-2004 R50 Pathfinders
Yeah, I should have mentioned that I'm trying to do this for relatively cheap. I found this one online... http://www.suspensionconnection.com/cgi-bin/suscon/224.html I really don't know if there are "good" hitches and "bad" hitches, but it looks decent to me (and fairly low profile). Anyone using this kind? WATYF -
Using 31X10.5's On A 96 Le (Vs. An Se)...?
Btw, thanks for all the input everyone. I'm really happy with the lift I got from these tires, and they seem to be working out just fine. I'll be taking them off road this coming Saturday, so we'll see how they work in a real-world scenario. WATYF -
I'll try to kill two mildly related birds with one stone here... I have a 96 LE and I'd like to get a tow hitch (low profile is preferred). I'd also like to know how easy it is to move the location of the spare tire. Right now, the spare is mounted underneath the rear (not the best location as far as I'm concerned). I've seen some threads mention a spare tire mounting system that involves the tow hitch itself, so if I can get them both in one deal, that would be great. I'd really like to have the spare moved to the back gate, but I'm not sure what needs to be done to make that happen. So could anyone recommend a tow hitch and/or spare tire mount that I could look into? Thanks. WATYF
OK. I guess I'll just leave it then. Don't wanna mess with fuel lines. So how about that load and speed rating? Does that seem fine? WATYF -
OK... so I take it that means I shouldn't even try to mod it, eh. WATYF -
OK, so I found some used 30x9.5x15's locally on craigslist for pretty cheap. They had a ton of tread left on them, so I thought it was a pretty good deal. At first, the shop I took it to actually told me that the tires weren't gonna fit. They had it up on the jack and put a new one up to the existing tire and the guy thought there was no way it would fit. I had already bought them (mainly because everyone here said that they would fit ), so I told him to just try one tire and if it didn't fit, I would pay him for just the one mount/unmount. So anyway, he gets it on and says it barely fit, so that was a crisis averted. Anyway, the truck looks much nicer now that it's not on such tiny tires. Here's a pic: So now, I only have two concerns... 1) The guy I bought them from said he couldn't find the load/speed rating on the tires, so I didn't know what it was until I got there. It's a 104Q. Now, my first thought was that 104 wasn't enough of a load rating, but it ends up that the previous tires were 102S, so I guess 104 is fine. The tires are Load Range C, which also seems like enough for this vehicle. Correct me if I'm wrong. I guess the only issue might be the speed rating. Q is pretty low, so I guess that means I have to keep my highway speeds down. Not like I was gonna go 100, but still... 80mph might be a little too much for these things. 2) The tires rub when I turn hard right (but not hard left). We checked this out and found out it's because of a piece that sticks out on the inside of the fender well on the right side (this same piece doesn't exist on the left side). Here's a pic of that (the rub occurs where the red dot is)... So, can anyone tell me what would need to be done to mod that so the tire doesn't rub any more? Should I flatten it or remove it entirely or...? Thanks for any input. WATYF
