1994pathfinder
Everything posted by 1994pathfinder
  1. alright thats what i thought i just wanted to make sure.
  2. there are two types of soft 8's, one with +6 offset and 4.75 backspacing and one with -13 offset and 4.00 backspacing. i should probably get the negative offset and less backspacing right?
  3. what offset and backspacing would you need to fit 32 x 11.5 wild country txr's on a 1994 with a 3in lift?
  4. What are the quickest/easiest ways to get some more horsepower out of a stock 1994? is the Nismo cold air intake worth $275, how much difference does it make? or would it be better to go with a new exhaust and if i do that, which is the best set up?
  5. so would a 31x10.5 r15 bf goodrich T/A KO be a good choice then? and do you know if those tires fit on the stock wheels?
  6. thanks for all the replies. so what is the biggest tire i can put on with the stock suspension, before i get the lift?
  7. Okay im looking to put a 3" suspension lift on my 94' pathfinder. im a little confused. Can you purchase a suspension lift with just lifting springs hardware and control arms without longer shocks, and just use that set up? or do they sell a suspension lift without shocks so that you can choose which shocks you want? if you can just use lifting springs and control arms, what are the shocks needed for or what do they help with? and after the 3" lift could i put on 265/85-r15 tires or would they be too big? thanks
  8. I have an old set of heads from a 91 maxima and i was wondering if they would work for my 1994 pathfinder, since the motor is basically the same.
