okpathfinder98
    99.5 4X4 Pathfinder LE
okpathfinder98's Achievements
  1. Actually when I put the fan on high it barely tries to blow and then turns itself down to low.
  2. The heater in the pathy is not blowing. I can hear it making some noise but no air flow. It is a 99 with the auto climate control. Thanks in advance for your help.
  3. The pathfinder does not kick over immediately,sometimes it takes a couple of times for it to start. Any help would be appreciated.
  4. One more thing: Its definately a groaning sound it very noticeable when backing out of the driveway. It doesnt sound like the high pitched sound of squeeling brakes.
  5. Thats a good point. Is there a way to tell if its brakes or bearings? I know the noise only happens when going slow in forward or reverse.
  6. I plan on changing the rear diff fluid. Never really messed with this before. I have searched on here and found that I should definately remove the plug first and to use the lsd additive. What else do I need to know about doing this? How do I drain it? Torque specs? New Gasket? Any tips would be greatly appreciated. 99.5 Pathfinder LE 4X4
  7. My check engine light is on for the rear right O2, when I replace it will the check engine light go off after driving a while or do I need to unhook the battery for a while? My second question is: Is there anything I can do to quiet down my noisy rear differential? Thanks in advance
  8. Thanks for the advice I will definately stay away from the stop leak crap. The leak does not look like its in the fins so Ill give her a shot.
  9. Yeah I got the code for the right rear 02. But before I replaced it I had to replace the battery so without power for a while the computer reset I guess and now the check engine light is not on. Im guessing the O2 is probably still bad? And my fuel mileage does suck. And I will try the jb weld.
  10. My pathfinders radiator has sprung a small leak. It is a small area along the top front of the radiator. It a small area that looks wet after engine warms up. There are signs of spray surrounding the area when the leak first happened I guess. Does anyone have expierience with the Stop Leak stuff for radiators? Or should I repalce the radiator? One more question: Will a faulty O2 sensor cause poor fuel mileage? Thanks in advance
  11. New guy here, cool forum. Are the two rear o2 sensors interchangeable? I have two of the drivers side o2s and the passenger side 02 is bad. Can I use the drivers 02 on the passengers side?
