Needalife
    '95 POS
    Screwdriver Mechanic
    Choose
    Choose
Needalife's Achievements
  1. 95 Pathfinder SE... Had to replace my starter and now I keep blowing fuses, top right one (meter is what it's marked as). Any ideas on what I could of done replacing my starter that would cause that fuse to blow as soon as I turn the key to the on position?
  2. Ok I've pulled the starter and replaced it even though it tested good. Still dead All connections are tight, tested relays and fuses again, tested new starter, tested battery. Any other suggestions? I can turn on the lights, try to start it and they do not dim at all. So that says to me that the starter is not getting power but I've tested all the wires and they are good. I doubt it but could it be the ECU? I am mechanically inclined not electrically on cars. Could I just have a short someplace?
  3. Needalife
    No start
    95 pathfinder, v6, auto Dead in driveway. Starter will not turn over, when I turn the key all I hear is one little click up in the engine compartment which I think is my fuel pump but I could be wrong. Starter does nothing, tried banging on starter but does no good. I've checked the battery and all wires I can get to. No blown fuses, checked the relays by swapping them around with like ones (same part #'s), have 12.26v at battery and if I'm checking it right have that to the starter. The fusible links are good. ECU is not putting out any codes. Tried starting in neutral and same thing. Please any suggestions as I'm tired of banging my head against the wall.
