tgullo1983
2001 Pathfinder, black, 60k
Screwdriver Mechanic
Choose
Rarely Go Off-Road
2001
Gender
Hamburg, NY
tgullo1983's Achievements
My springs really dont sag at all, I just thought it might give me a little extra room with the strut spacer. I dont do a ton of off-roading so im going to go with BF Goodrich all-terrain ta's. Ive run these tires before and you can beat them in the snow and ice, I live in Buffalo, Ny so we get a good amount of snow.
Thanks for all the help I think Im gonna get the strut spacer and just go with the 255/70/16, I dont wanna push it. The 245/75/16 are cheaper and there a little taller thats why i was debating so much.
Do you think the strut spacer will give me any more clearance to run the 245/75/16? Or just play it save wtih 255/70/16 its only .4 of an inch difference bigger wont make much of a difference.
Will a strut mount spacer on the front give me that little extra to make the 245/75/16a better fit? Also do the strut mount spacer screw up the camber and the angle of your cv axle?
What about the strut mount spacer does that even make any difference? Do they change the angle of the camber resulting in premature cv wear?
Ill go for it then Ill take the front mud flaps off, and put the 1" strut spacer on and get the 245/75/16. By the way it looks i have over an inch to the mud flap now with the stock tires so hopefully Ill be ok. Thanks for all the help
With the 255/70/16 where is the closest possible place it can rub? And how much room do you have at full turn? Is it on the mud flap? Because thats an easy solution take the mud flats off the front
What size tire are those on your PF duckling
full lock in reverse, Do you mean the wheel turned all the way?
I plan on getting the BF Goodrich all-terrain ta, just trying to get the biggest possible with no embassasing rubbing when I driving? What about the strut spacer with that give me the room for the 245/75/16? Seems like it would be close by what you are all saying
Im looking to get some new tires for my PF, What is the biggest size I can get without a lift and to make sure they dont rub? Im goin to put 1" strut mount spacers on the front to maybe help a little. Are 245/75/16s out of the question? Does anybody run with this set up? Some feedback please looking to order soon
is there any added room with the strut mount spacer to maybe allow a little bigger tires?
Isnt that the same size as stock? Anybody with the 255/70/16? I wanna make sure Im not gonna have to be cutting fender walls to stock rubbing
thanks for the help
what size strut spacer and where do I get them from?
