prplhz96
Everything posted by prplhz96
  1. If I buy a heavy attack weapon, can I use it for a personal attack, or are they for like gang wars only or something?
  2. Thanks. On a side note, where can I "borrow/rent" a big shop like the nucleur research place to get my stats up faster. I hit the gym every chance I get, but im only getting like 1500 each time with my current shop.
  3. How do I recharge energy now. The announcement said that now oil does it...........Where do I go to use oil to recharge it???
  4. good thing i didnt make it in the gang i guess......did you guys lose alot of stuff?
  5. Is the item market the only way to get will bottles??????
  6. I figured I would give this game a try, sort of confusing but I am sure after a few days it wll get easier. Any help would be appreciated, I just have the basics as of now, tires, x fer case, fi v6. 9234 prplhz96
  7. Once you get the a-pillar off, you can unplug the tweeters, instead of snipping the wires. If you ever want to add new ones all you have to do is plug them in. I had a "blown" one, just got another one from the junkyard and it works like new again.
  8. Just replace the bulb, composite headlamp.
  9. Just wondering if you have one ready to ship. If you do pm me and i can send some $$$ your way.
  10. do you have an interlock switch?????? Reason I ask, is my truck does the same thing even with the interlock button depressed, when it acts up that is
  11. I have the same exact problem with mine. The only trick that I learned over the past few months is to wiggle the key while trying to start and it turns over. I believe my problem is the ignition switch(lock cylinder). Whenever I get around to it, I am going to pick up a new one and see what happens. For now, I'll just stick with the "wiggle".
