JF5000
    I have a blue 1993 4WD Pathfinder.
    XE
    Fort Bragg
JF5000's Achievements
  1. Hello! This question has already been asked I’m sure. I also searched the forum prior to making this post and was unable to find an answer. If someone could point me in the right direction I would really appreciate it. Situation: 1993 Pathfinder sat for 1 year without a battery. Replaced the battery and now the vehicle runs a little rough and does not idle well (low idle). My initial assessment is that the onboard computer has forgotten the settings for various electronic components. Question: Will the computer learn the proper settings after several driving cycles like some cars do? Or will this require a manual solution? Again your help in this matter is appreciated. V/r James
  2. Thanks Man! I got her put back together, runs like a Champ!
  3. Hey everybody thanks for the input for this problem! I just want to know the space between the transmission and the transfer-case, will the oil from the transmission fill this void or does it come from the transfer-case. Which brings another question to mind, " do you use the same type of oil in the transfer-case as the transmission". It would seem obvious it would, I just wanted to be sure.
