cdhicks99 Posted July 18, 2006 Share Posted July 18, 2006 I had a very hard time locating the exact Pro-Comp shock part numbers. So here it is for future reference along with specs. Rancho RS5116 Internal Design: Twin-tube Adjustable: No Gas Charged: Yes Bushing Material: Rubber Bushing Color: Black Boot Included: Yes Boot Color: Red Extended Length (in): 24.000 in. Collapsed Length (in): 14.875 in. Upper Mount: Eyelet Lower Mount: Eyelet Pro-Comp 324509 Internal Design: Twin-tube Adjustable: No Gas Charged: No Bushing Material: Rubber Bushing Color: Black Boot Included: No Extended Length (in): 24.840 in. Collapsed Length (in): 14.820 in. Body Diameter (in): 2.360 in. Upper Mount: Eyelet Lower Mount: Eyelet Link to comment Share on other sites More sharing options...
cdhicks99 Posted July 18, 2006 Author Share Posted July 18, 2006 Oh yeah and the stock type specs. Rancho RS5118 Internal Design: Twin-tube Adjustable: No Gas Charged: Yes Bushing Material: Rubber Bushing Color: Black Boot Included: Yes Boot Color: Red Extended Length (in): 22.250 in. Collapsed Length (in): 14.000 in. Upper Mount: Eyelet Lower Mount: Eyelet Pro-Comp 322500 Internal Design: Twin-tube Adjustable: No Gas Charged: No Bushing Material: Rubber Bushing Color: Black Boot Included: No Extended Length (in): 22.580 in. Collapsed Length (in): 13.710 in. Body Diameter (in): 2.360 in. Upper Mount: Eyelet Lower Mount: Eyelet Link to comment Share on other sites More sharing options...
Precise1 Posted July 18, 2006 Share Posted July 18, 2006 Nice, thanks... I'll pin it soon... B Link to comment Share on other sites More sharing options...
offroad95pathy Posted July 22, 2006 Share Posted July 22, 2006 (edited) If anyone is interested, here's the info for Rancho RS9000X series that fit 87-85 Pathfinders: Rancho RS99214 (Front) 1.5/3.0” SL Lift Internal Design: Triple-tube Adjustable: Yes, 9 Position Gas Charged: Yes, (cellular gas/compressed air) Bushing Material: Polyurethane Bushing Color: Red Boot Included: Yes Boot Color: Red Extended Length (in): 14.500” Collapsed Length (in): 10.375” Travel: 4.125” Upper Mount: stud Lower Mount: Eyelet Rancho RS99116 (Rear) 1.5/3.0” SL Lift Internal Design: Triple-tube Adjustable: Yes, 9 Position Gas Charged: Yes, (cellular gas/compressed air) Bushing Material: Polyurethane Bushing Color: Red Boot Included: Yes Boot Color: Red Extended Length (in): 23.750” Collapsed Length (in): 15.000” Travel: 8.750” Upper Mount: Eyelet Lower Mount: Eyelet Rancho RS99112 (Rear) 4.0/6.0” SL Lift Internal Design: Triple-tube Adjustable: Yes, 9 Position Gas Charged: Yes, (cellular gas/compressed air) Bushing Material: Polyurethane Bushing Color: Red Boot Included: Yes Boot Color: Red Extended Length (in): 26.000” Collapsed Length (in): 16.125” Travel: 9.875” Upper Mount: Eyelet Lower Mount: Eyelet Edited August 7, 2006 by offroad95pathy Link to comment Share on other sites More sharing options...
TrailChaser Posted July 22, 2006 Share Posted July 22, 2006 I suggest running the RS5112 if you have a lift and disconnect the rear swaybar while offroading. Brand: Rancho Product Line: Rancho RS5000 Shocks Internal Design: Twin-tube Adjustable: No Gas Charged: Yes Bushing Material: Rubber Bushing Color: Black Boot Included: Yes Boot Color: Red Extended Length (in): 26.250 in. Collapsed Length (in): 16.000 in. Upper Mount: Eyelet Lower Mount: Eyelet Link to comment Share on other sites More sharing options...
cdhicks99 Posted July 23, 2006 Author Share Posted July 23, 2006 The Ranchos are very easy to get pn's for it's the pro-comps that gave me such a fit. Link to comment Share on other sites More sharing options...
revgrizzly91 Posted December 12, 2006 Share Posted December 12, 2006 Are they electrically controlled like the factory ones or is that function not applicable once you swap em out. I rather like switching from soft to firm at a moments notice Link to comment Share on other sites More sharing options...
mws Posted December 12, 2006 Share Posted December 12, 2006 Nope. I am not aware of any aftermarket shocks compatible with the OEM switch. However, the RS9000's are adjustable, and Rancho offers a dedicated remote control adjustment system for them. $$$, but slick. Link to comment Share on other sites More sharing options...
flnl Posted March 16, 2007 Share Posted March 16, 2007 (edited) I suggest running the RS5112 if you have a lift and disconnect the rear swaybar while offroading. What about Pro Comp? Wouldn't the 324509 mensioned above be a little short if you use to disconnect the rear swaybar? I've searched the Pro Comp's catalog and found that 325500 is a little longer: Extended Length (in): 25.740 in. Collapsed Length (in): 15.490 in. Edited March 16, 2007 by flnl Link to comment Share on other sites More sharing options...
msavides Posted August 2, 2007 Share Posted August 2, 2007 If anyone is interested, here's the info for Rancho RS9000X series that fit 87-85 Pathfinders: Rancho RS99214 (Front) 1.5/3.0” SL Lift Internal Design: Triple-tube Adjustable: Yes, 9 Position Gas Charged: Yes, (cellular gas/compressed air) Bushing Material: Polyurethane Bushing Color: Red Boot Included: Yes Boot Color: Red Extended Length (in): 14.500” Collapsed Length (in): 10.375” Travel: 4.125” Upper Mount: stud Lower Mount: Eyelet Rancho RS99116 (Rear) 1.5/3.0” SL Lift Internal Design: Triple-tube Adjustable: Yes, 9 Position Gas Charged: Yes, (cellular gas/compressed air) Bushing Material: Polyurethane Bushing Color: Red Boot Included: Yes Boot Color: Red Extended Length (in): 23.750” Collapsed Length (in): 15.000” Travel: 8.750” Upper Mount: Eyelet Lower Mount: Eyelet Rancho RS99112 (Rear) 4.0/6.0” SL Lift Internal Design: Triple-tube Adjustable: Yes, 9 Position Gas Charged: Yes, (cellular gas/compressed air) Bushing Material: Polyurethane Bushing Color: Red Boot Included: Yes Boot Color: Red Extended Length (in): 26.000” Collapsed Length (in): 16.125” Travel: 9.875” Upper Mount: Eyelet Lower Mount: Eyelet where did you find the info on the shock length. I have some part numbers that i was trying to find the length on and I cannot find that info anywhere. Mark Link to comment Share on other sites More sharing options...
MadManMike Posted October 5, 2007 Share Posted October 5, 2007 Oh yeah and the stock type specs. Rancho RS5118 Internal Design: Twin-tube Adjustable: No Gas Charged: Yes Bushing Material: Rubber Bushing Color: Black Boot Included: Yes Boot Color: Red Extended Length (in): 22.250 in. Collapsed Length (in): 14.000 in. Upper Mount: Eyelet Lower Mount: Eyelet Pro-Comp 322500 Internal Design: Twin-tube Adjustable: No Gas Charged: No Bushing Material: Rubber Bushing Color: Black Boot Included: No Extended Length (in): 22.580 in. Collapsed Length (in): 13.710 in. Body Diameter (in): 2.360 in. Upper Mount: Eyelet Lower Mount: Eyelet Are these the front or the rear? or do they go on all 4? -Mike Link to comment Share on other sites More sharing options...
jj big shoe Posted October 7, 2007 Share Posted October 7, 2007 (edited) Are these the front or the rear? or do they go on all 4?Those particular ones are for the rear. If it has eyelets for both upper and lower mounts its a rear shock. Front shocks have a stud for the upper mount and an eyelet for the lower. Edited October 7, 2007 by jj big shoe Link to comment Share on other sites More sharing options...
wheel366 Posted May 1, 2008 Share Posted May 1, 2008 Anybody have the part number for the Rancho 5000's for the front? I may need new shocks. I seached through like 15 pages and can't find them. Link to comment Share on other sites More sharing options...
slade420 Posted October 28, 2008 Share Posted October 28, 2008 i would also like to know the rancho 5000 pin for the front. with the jgc lift. new to the forum. just got a 93 4 door/without the exterior rear tire carrier. Link to comment Share on other sites More sharing options...
KovemaN Posted May 22, 2009 Share Posted May 22, 2009 The Rancho P/N for the front is RS5214 (5000), RS99214 (9000X) or RS999214 (9000XL) Here is a list of the Rancho 5000 part numbers with the correct mounting for the rear shocks. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted December 30, 2009 Share Posted December 30, 2009 This is a "budget shock" that you can get @ autozone from gabriel that is only 17 bucks....this is the size and stuff if your lifted and want good flex, I dunno how well it would work for you, but in theory it is a perfect solution. You have to order the shock as being for a stock 1995 f150 which gets you the correct length and such, so yeah Part Number: 81510 Weight: 4.1 lbs Warranty: LLT Application: Without lift kit Notes: Shock Category Name: Guardian Shock Internal Design: Twintube Adjustable: No Gas Charged: Yes Hardware Included: No Quantity: Sold Individually Extended Length: 25.73 In. Collapsed Length: 15.12 In. Stroke: 10.61 In. Instructions included: No Link to comment Share on other sites More sharing options...
Slick Posted January 16, 2010 Share Posted January 16, 2010 I am going to add to this...... IF........ you have the Trail Master susp lift, or you have a combination of 3" BL and 4" SL, there is no Rancho listed for the Pathfinder that fits. (oh trust me, I know now! event he Rancho 9000XL is about 4-5" too short!) Go direct to Trail Master to get the shocks that fit. I will post p/n's when I have access to them. (they are listed right on Trail Masters site) Link to comment Share on other sites More sharing options...
tmoore4512 Posted May 23, 2010 Share Posted May 23, 2010 Another option from the shelves of your local Autozone... As I was working one night, I started sifting through part numbers of various shocks, looking to replace mine on the cheap when I finally install my SL... The factory front specs are as follows: Extended length: 14.95 inches Collapsed length: 9.67 inches Stroke length: 5.28 inches (I have not found the F150 shocks mentioned earlier. Maybe something changed?) The factory rear specs are as follows: Extended length: 22.49 inches Collapsed length: 13.69 inches Stroke length: 8.80 inches I am thinking about swapping in a set of Gabriel Hi Jacker air shocks for the rear, since I have the rear tire carrier, and will put my full size spare on it, when I get time...thus it will probably sag more so, and the extra boost the air shocks will provide will help to level things up. Here are the Hi Jacker specs for the rear. These are actually Chevrolet/GMC K1500 4WD rear shock specs, but will compensate for the lift... Extended length: 26.33 inches Collapsed length: 16.35 inches Stroke length: 9.98 inches The Chev/GMC shocks are about 25 bucks cheaper than the Nissan replacement, and they sure do look beefier. Had them out of the box and was checking them out, no comparison...especially with a lifetime warranty. Link to comment Share on other sites More sharing options...
tmoore4512 Posted May 23, 2010 Share Posted May 23, 2010 I have seen a few ebay stores that claim to sell a complete set of shocks for "lifted" pathfinders, $140 range...but I dont know the quality...(chinese stuff...oh yeah!!!) Man, a few years ago a buddy of mine found a website that specialized in shocks. He ordered a set for his Toyota, and was able to "customize" his shocks. What I mean is, he entered his lift, how much articulation he wanted, the extended length and collapsed length of the shocks, etc. They were very beefy shocks, and he didn't pay an arm and a leg for them...I just cannot for the life of me recall what dang site it was. Any suggestions? Link to comment Share on other sites More sharing options...
RedPath88 Posted May 23, 2010 Share Posted May 23, 2010 Call 4wheelparts directly when ordering, they can put any size shocks you want in the "package deal" I ordered a set of ES3000's long ago and had them replace the stock sized rears with a set that were longer (listed for a Toyota) to gain more downward travel on the rear axle. Still priced at the special they were running at the time (4 shocks + SS) And remember, that the fronts remain stock sized even when lifted. Link to comment Share on other sites More sharing options...
tmoore4512 Posted May 23, 2010 Share Posted May 23, 2010 Thanks for the info regarding the front. I was hunting an extended length but glad I did not purchase. I read somewhere about the Trailmaster 4 inch kit using extended shocks, or adapters on their lift for the front...I assume that is because they dropped the lower control arms down? Dunno, that kit has been discontinued for some time now... I have dealt with 4Wheelparts a few times, good people. Every once in a blue moon they have a great deal on stuff...clearance etc... Link to comment Share on other sites More sharing options...
piste Posted June 3, 2010 Share Posted June 3, 2010 Anyone have any thoughts on the Rancho RSX17000's? I've had them in my 97 SE and am due to replace. Was going to do RS5000 but figure the RSX17000 would be a worthwhile upgrade.? Link to comment Share on other sites More sharing options...
bro_die Posted March 15, 2011 Share Posted March 15, 2011 What rancho shock will fit a 2001 path with a 4In SFD. Getting closer to purchasing the lift BUT all I need is this rear shocks because they said the front can be reused but I will upgrade later on down the line. Link to comment Share on other sites More sharing options...
WarehouseRat Posted June 23, 2011 Share Posted June 23, 2011 I'm picking up a set of pro comp es 9000 today Link to comment Share on other sites More sharing options...
Nefarious Posted November 10, 2014 Share Posted November 10, 2014 Trailmaster definitely uses 4 inch longer shocks front and rear. There's a knuckle adapter that drops the front lower control arms, crossmember, and diff down 4 inches and the knuckle adapter takes up the space in between the lower suspension and the steering links. Link to comment Share on other sites More sharing options...
