Hello my name is aaron and i’m new
just joined in and i already like it. i like how everyone just helps around and not talk about about anything people need help on. Im from covington louisiana and i have a 1995 nissan pathfinder xe 4x4 manual with 255,345 original miles. i already have a question about my pathfinder and it’s the oil light coming on a flickering on a off and when i turn the light turns off. another thing the abs and the hand break light turn on for a couple of minutes and turn back off.
:welcome:
Check the wire to the oil pressure switch. Hopefully you've got a damaged/dangling wire grounding out, which would make sense with it going off on turns (wire swings away from whatever it's hitting). IIRC it's up above the starter, near the oil filter. I am assuming you've already checked the oil!
IIRC ABS and BRAKE come on when the brake fluid is low. Check the brake fluid level in the reservoir. There's a little float switch inside that trips the light when the level falls lower than it should.
