Terryw Posted May 22, 2021 Share Posted May 22, 2021 Headlights don’t come on unless bat is applied to fuses under hood any suggestions Link to comment Share on other sites More sharing options...
adamzan Posted May 22, 2021 Share Posted May 22, 2021 The switch on the steering column is notorious for going bad. Take it apart and look at the contacts. Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 23, 2021 Share Posted May 23, 2021 The switch is a common failure point, but it's got one contact for each filament (left low, right low, left high, right high) so usually you'll only lose one side, in one position. At least that's what mine did. Yours sounds more like the switch isn't getting power. Do the parking lights still work? Link to comment Share on other sites More sharing options...
SpecialWarr Posted May 25, 2021 Share Posted May 25, 2021 (edited) Vampire bat? They tend to consume power... you might want to try a fruit bat next time! Seriously though: I would think that a plug has come undone since full power comes direct to switch at the column and most of the time only one circuit cuts out ( as the fine gentlemen above noted) except for that one guy who lost both high and low beams at the same time.... guy from Saskatoon? Edited May 25, 2021 by SpecialWarr can't spell sas-ka-toon correctly... Link to comment Share on other sites More sharing options...
