wd21 Rear corner window trim
Hello all peoples, I am in the process of restoring my first car ('91 SE-V6) to be my daily and I want to do paint and body but I cannot find anything on the rear door corner (half) window rubbers.  Any help would be great
I've been wanting to do the same. I think most of that stuff is nearly unobtainium right now. Maybe Safelite or one of the glass companies has a source for the rubber. Past that, if you're looking for the plastic pieces of trim, you're likely going to have to go to a junk yard.
thanks for the reply,  I actually am wanting the rubber trim around the corner window that doesn't move.  I am wanting to repaint and thought that would be good to replace being that I hope to replace all other seals/belt trim on the truck.
Someone... MY1PATH?... talked about buying some window trim that was either "generic" by the length or from another auto maker that fit well. All I can do is recommend searching for it.
As for the original, that doesn't exist as far as I know. Trust me, I need some badly too...
