CV SHAFTS
Teesetz
So I am going to be doing replacing both my CV shafts soon. I have a Chiltons manual that is for 89-91.
My Pathfinder is a 94. Being that 86.5-95 are categorized as WD21S is it going to be the same in the manual, or do I need to get a manual for 90-95?
The '94-'95 FSM (free download from Nicoclub if you haven't already) will be more applicable to your truck than the earlier Chilton, but AFAIK the procedure to replace the CVs should be the same for any 4WD WD21.
The thing that hung me up when I did mine were the stupid twelve-point bolts holding them in. I didn't have a twelve-point 12mm impact socket, so naturally I destroyed a chrome socket before borrowing the one I needed. I haven't found a torque spec for those bolts, but I didn't install them with a torque wrench.
