AlwaysWrenching Posted November 4, 2020 Share Posted November 4, 2020 The blower motor for the heat and AC does not work on any setting. There is power to both wires going to the motor. However when the motor is hooked up directly - one wire +, one -. It spins just fine. Did the resistor fail? Link to comment Share on other sites More sharing options...
Mr_Reverse Posted November 4, 2020 Share Posted November 4, 2020 Do you have the auto or manual controls? It sounds more like the control head has a problem. If it was a bad resistor, it would work on high setting since that bypasses the resistor. Link to comment Share on other sites More sharing options...
