enochian Posted September 15, 2020 Share Posted September 15, 2020 So I am assuming the black rod is the rear sway bar? Link to comment Share on other sites More sharing options...
colinnwn Posted September 15, 2020 Share Posted September 15, 2020 Nope. That's a panhard rod. It provides the side to side location support of the axle to the body, so the axle doesn't go scampering off to the left or right. Sent from my SM-N950U using Tapatalk 1 Link to comment Share on other sites More sharing options...
prmanke1232 Posted September 15, 2020 Share Posted September 15, 2020 That is not your sway bar. Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
enochian Posted September 15, 2020 Author Share Posted September 15, 2020 So where is the sway bar? Link to comment Share on other sites More sharing options...
colinnwn Posted September 15, 2020 Share Posted September 15, 2020 Look on the other side of the axle towards the front. It will have an arch over the pumpkin, and short arms that L forward, and then 2 short links that go up to connect to the subframe.Sent from my SM-N950U using Tapatalk 2 Link to comment Share on other sites More sharing options...
enochian Posted September 15, 2020 Author Share Posted September 15, 2020 (edited) Is this it? How do I remove it? https://i.ibb.co/wNPh5JX/IMG-20200915-094010131.jpg Edited September 15, 2020 by enochian Link to comment Share on other sites More sharing options...
colinnwn Posted September 15, 2020 Share Posted September 15, 2020 Yes I think that's it but pic is blurry and dark.I've never had to replace mine. I think you'd just remove the top links, remove the bar bracket, then hopefully tetris it out. Might have to remove wheels.Would be best to review service manual. Probably has detailed steps. Sent from my SM-N950U using Tapatalk 1 Link to comment Share on other sites More sharing options...
XPLORx4 Posted September 15, 2020 Share Posted September 15, 2020 Unbolt the brackets holding the sway bar to the axle and remove the nuts holding it to the sway bar links. 1 Link to comment Share on other sites More sharing options...
