NuggetRaider Posted August 15, 2020 Share Posted August 15, 2020 I have bought a 1990 pathfinder and have some work to do as its got 200k when i bought it. 5 speed non 4wd. I got the timing belt done and did an oil change. My biggest problems currently seem to be oil leak from driver side valve cover gasket, exhaust leak somewhere on the passenger side, and tailgate isn't adjusted right so water leaks in anyway here is picture. 1 Link to comment Share on other sites More sharing options...
FirstGenFreak Posted August 15, 2020 Share Posted August 15, 2020 Congrats on the purchase, they are all minor problems so you've done well That is one chunky side step haha Looks real clean! Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 16, 2020 Share Posted August 16, 2020 Paint looks good! Valve cover gaskets are a common failure on these, and not too bad to do, though you will have to remove the upper intake manifold to get to the driver's side. Plan to replace the vacuum lines while you're at it if they're original. It's also a good time to do the spark plugs, just because the driver's side bank will never be easier to access than it is with the upper intake removed. The exhaust studs tend to snap off, that's probably what's causing your exhaust leak. I know it's what's causing mine. Good luck with the tailgate, hopefully a little tweaking sorts it out. The service manual (you can download a '90 manual free off Cardiagn) may have some explanation of how that's supposed to be set up if you get stuck, and is a good thing to have around anyway. And yeah, that's quite the nerf bar! Link to comment Share on other sites More sharing options...
NuggetRaider Posted August 17, 2020 Author Share Posted August 17, 2020 Thanks for the info, on a side note does anyone know where I can find the original seat oem cloth my drive side is torn a little and will only get worse i'm sure. Link to comment Share on other sites More sharing options...
FirstGenFreak Posted August 17, 2020 Share Posted August 17, 2020 Cut a good section out of a wreck or you could try SMS auto fabrics. They have a vast range. Link to comment Share on other sites More sharing options...
NuggetRaider Posted August 18, 2020 Author Share Posted August 18, 2020 I'll try them out, I don't wanna have to redo all seats because somethings not matching the others. You wont happen to know where I can fight one of the back door ashtrays that flip out. I looked but couldn't find one I need only one. Link to comment Share on other sites More sharing options...
