Datsunofagun Posted June 7, 2020 Share Posted June 7, 2020 Looking for some guidance. Trying to find a drier fir my AC but the stock one has 3 outlets. One for intake from condensor, one for outlet and one for a pressure cutoff valve to attach. Every replacement I see has only intake and outlet. Any ideas? Link to comment Share on other sites More sharing options...
adamzan Posted June 7, 2020 Share Posted June 7, 2020 It may be because the replacements have a bolt threaded into where the sensor goes in the pictures. You just remove it to put the sensor in. Link to comment Share on other sites More sharing options...
Datsunofagun Posted June 7, 2020 Author Share Posted June 7, 2020 (edited) Thanks for the reply. I thought that at first but the stock one has a fitting that screws onto the sensor. The fitting is part of the drier assembly and is not removable (to me at least). Any one replaced a drier for a 94-95 with this issue? Edited June 7, 2020 by Datsunofagun Link to comment Share on other sites More sharing options...
adamzan Posted June 7, 2020 Share Posted June 7, 2020 Can you post a picture of what you have? I replaced the one on my 1995 and it was as simple as screwing the old part into the new drier. Link to comment Share on other sites More sharing options...
Datsunofagun Posted June 8, 2020 Author Share Posted June 8, 2020 This is the part that looks to fit. But it is no longer being produced. https://www.amazon.com/Four-Seasons-W0133-1622522-Receiver-Drier/dp/B00449SR8K Link to comment Share on other sites More sharing options...
Datsunofagun Posted June 8, 2020 Author Share Posted June 8, 2020 This is the part Ebay, Amazon, Partsgeek, RockAuto says will fit. But no fitting for the pressure switch. https://www.ebay.com/itm/A-C-Receiver-Drier-Filter-Drier-4-Seasons-33415/192826650855?epid=74406760&_trkparms=ispr%3D1&hash=item2ce55d30e7:g:PagAAOSwLIVeTF0i Link to comment Share on other sites More sharing options...
Datsunofagun Posted June 8, 2020 Author Share Posted June 8, 2020 So here is a part that has the fitting, but the outlets are off. Maybe use an adapter to make the outlets match and use this? https://www.amazon.com/gp/product/B00CFQS3UQ/ref=ox_sc_act_title_3?smid=ATVPDKIKX0DER&psc=1 Link to comment Share on other sites More sharing options...
dmvhornback Posted July 26, 2022 Share Posted July 26, 2022 did you ever figure it out? i just bought that drier and idk if its going to fit either... Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 30, 2022 Share Posted July 30, 2022 I haven't tried to install it yet, but I bought a GPD drier for mine, PN 1411457, via Rockauto IIRC. It has bolts going into both sides at the top, one of which I assume I can just remove to install the pressure switch, possibly using a fitting from the old drier. One of these days I'll get around to fixing my aircon, but this is not that day. Link to comment Share on other sites More sharing options...
adamzan Posted July 31, 2022 Share Posted July 31, 2022 That looks like the same one I have. It fit my 1995 just fine. You have to remove one of the plugs to screw in the pressure switch. Idk about you guys but I can't live without the aircon in mine. Black truck with leather seats.... Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 3, 2022 Share Posted August 3, 2022 Black with cloth is bad enough! Link to comment Share on other sites More sharing options...
adamzan Posted August 8, 2022 Share Posted August 8, 2022 Yup. Mine worked when I bought it but I had to redo it after something hit the condenser. I bought a vacuum pump and set of gauges. It gets down to the low 40s or high 30s. Coldest air of any car I own lol. Link to comment Share on other sites More sharing options...
