rboat88h
Tach power 97 pathfinder?
I have one of the many bad tachs that came on the 97 pathfinder. I have tried all the fixes on the internet and it still dances around all over. The junkyards do not have any and they do not make new ones. So I simply want to disconnect power to the tach. Does anyone know which wire I can disconnect? I already tried the fuse but that takes power away from the entire cluster. If you have a wiring diagram or know which wire please let me know. Thanks. Love my truck, but the dancing tach is driving me crazy.
Try checking page EL-84 and following in the service manual, linked below
https://www.dropbox.com/s/pafywl7qwwmpj0t/EL.pdf?dl=0
If you can not determine which wire disabled the tach, you could remove the cluster, pop off the clear plastic cover and remove the needle from the tach.
You tried re-soldering the 4 main pins? I had this exact problem on my 96, I soldered the pins and It’s still holding up 5 years later.
But if you just wanna turn it off, do what he ^^ said.
-Kyle
