missionstreet Posted November 27, 2019 Share Posted November 27, 2019 Looking for a connector for trailer lights on my 98 (built in 97). I see a connector rear passenger side on the frame rail near bumper, does anyone have any info on that plug? Thanks Link to comment Share on other sites More sharing options...
colinnwn Posted November 27, 2019 Share Posted November 27, 2019 I can't think of what open connector there is back there.Here is what you need if you don't have the factory version already. It splices in with factory plugs between each tail lampHopkins 43565 Plug-In Simple Vehicle Wiring Kithttps://www.amazon.com/dp/B0002Q7ZU0/ref=cm_sw_r_cp_apa_i_v0N3Db12P9C17Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
Strato_54 Posted November 28, 2019 Share Posted November 28, 2019 (edited) there is no open connector thats only on the pickups of that year. Youre going to have to run the wires another way. I didnt have the piggy back plug and play but running the wires is easy. if you run the wires under the trunk lining near the lock there are 2 decent sized holes for it to go through. i ran my 7pin wiring cable through that hole and to my plug which is on my bumper. If you are able to get an actual signal from that "open connector" make sure with a test light its what you actually think it is because from what ive seen the tail lights only run inside of the cab. EDIT: youre going to need something like this and if you want the 7pin plug you just cut off the 4 pin plug and wire it to a 7 pin plug instead. then all you have to do is run your brake wire and your 12 volt wire to the dash and then after that its up to you how that works. you dont need the 12v wire or a brake wire but if you want the 7 pin thats the best way i found plus its cleaner Edited November 28, 2019 by Strato_54 Link to comment Share on other sites More sharing options...
missionstreet Posted December 14, 2019 Author Share Posted December 14, 2019 Link to comment Share on other sites More sharing options...
Strato_54 Posted December 14, 2019 Share Posted December 14, 2019 9 minutes ago, missionstreet said: i dont think thats a factory harness for the trailer plug. i would take a test light to it and test it incase im wrong Link to comment Share on other sites More sharing options...
missionstreet Posted December 14, 2019 Author Share Posted December 14, 2019 (edited) Yeah I've got the FSM and the connector section shows something back there I think, not sure if it's that plug. I've seen in Chrysler FSMs entire sections showing every single plug. Edited December 14, 2019 by missionstreet Link to comment Share on other sites More sharing options...
