HI !!!
I do not own a pathfinder, I have a king cab, 4x4, d21 with what i believe has the same engine as some of the older pathfinders.
(z24s carburated, point ignition, 4 plugs, 1 ignition coil and external resistor and single points).
There is only 2 wires on the distributor , one is blue and is going to the ignition coil negative side , if disconnected the engine stops.
The other on is Black with a yellow stripe on it and it goes in to the main harness., if disconnected no
