Cosbool Posted May 20, 2018 Share Posted May 20, 2018 Hey guys. I have a questiin. I have a 2002 infiniti qx4. It has overheating issue. While I was driving, I was reving around 5000rpm and suddenly, I felt engine power is all gone for a sencond. After that, coolant was come off from reservoir line and having overheating issue. I replaced a thermostat, radiator cap. And I did air bleeding well, and heatercore bypass. But still issue. So I went dealership and they checked pressured on cooling system and they told me It seems water control valve problem. Here is my question. Does anyone know how to replace water control valve and where it is? Thank you and have a wonderful day. Link to comment Share on other sites More sharing options...
CNAM Posted May 20, 2018 Share Posted May 20, 2018 I am about to replace both thermostats and the water pump on mine. It’s been slightly overheating. These trucks have two thermostats that control the coolant flow through the cooling system. I would recommend using OEM Nissan parts. I’m not sure there’s any other type of water control valve other than the thermostats. And if they begin to get stuck the truck will run hot. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Cosbool Posted May 20, 2018 Author Share Posted May 20, 2018 Thank you for the information. The water control valve that mechanic was talking about is I guess those one of the thermostat that you mentioned. May I ask you the where the thermostats located and How did you replace it ? Mine has overheating issue very high not slightly. Thank you. Link to comment Share on other sites More sharing options...
Cosbool Posted May 20, 2018 Author Share Posted May 20, 2018 I found a pic of engine. And I believe No.2 is the thermostat that you replaced. Am I right? Thank you. Link to comment Share on other sites More sharing options...
Cosbool Posted May 20, 2018 Author Share Posted May 20, 2018 https://goo.gl/images/1GQtqq Link to comment Share on other sites More sharing options...
deltaR50 Posted May 21, 2018 Share Posted May 21, 2018 the other thermostat is located behind the engine. only way to access is to remove the whole intake manifold. Link to comment Share on other sites More sharing options...
