Gas Gauge
kdj
I'm hoping someone can help me out. I have a 2003 with a gas gauge that has quit working. It goes to full as soon as the key is turned on. The tank is grounded and I have tried pluging in another sending unit and it reads the same. I cant see the gauge itself failing. Is there a relay in there some where that might have failed. I've had to replace the one for the blower and one for the front amp, so I could see another one quitting. I have a wire diagram but can't find anything. Any ideas? I don't like carrying a can of gas with me...just in case. Thanks
Not sure about a relay in the system, sorry I can't help you there, but wouldn't it be easier to track when you need gas by using the trip odometer, instead of carrying extra gas around?
Yes I use the trip meter but I have run out once after a loose battery cable caused it to reset the meter. I figured that out after I ran out. I'd just rather fix the gauge.
