No power to window switch
Zkingcyrus
Im not getting any power to the switch. Windows stuck up, automatic locks not working either. It happenend a few times and completely quit today. I pulled the amplifier but capacitors tested fine and toggle were clean/unburned. I can't figure out which relay/fusible linke feeds power to windows, any guidance would be appreciated.
I tested the 5 fusible wires that come off of the battery (lead to negative terminal). All were showing 12v. When I tested the other sides of the circuit (from battery terminal); 1/5 show 12v with the key off, 4/5 show 12v with the key on. The door lock button is also not working. The windows were working momentarily today but everything died again after I put 2 down.
Well, I tried "everything". I pulled up the gsm and followed the diagram searching for the "circuit breaker" next to the fuse panel. Finally gave up and decided to swap a few grounding screws before I put it back together and that ended up solving my problem. Good luck to everyone else with window issues!
Try this for the door locks...
NOTE: As mentioned at the bottom of the FSM Page.. The circuit breaker for the Door Lock is the same as for the POWER WINDOWS!!
Good luck!
Edited by OH6PILOT
Thanks for the info OH6, I'm gonna take a look at this within the next couple of weeks.
Ever since last year when I took my Pathy in to have the alignment done, my mechanic (without asking) attempted to fix my ABS light which has been on for 10+ years now; he failed. In the process he managed to make my power locks quit unlocking. They still lock, but when you go to unlock the doors, there's an audible clicking from what I can only assume is some sort of relay under my driver side dash. This is why I try to work on my rig rather than take it to a mechanic!
Good luck!
