UPDATE - Unfortunately, the data that was lost is unrecoverable by the host.  If you joined between May 26th and Jan 13th please feel free to sign up again.  In addition, all posts and messages during that time have also been lost.  At this point there is nothing that can be done, other than to move forward from here.
Thank you for your patience and understanding.
-NPORA Mod Team
*Updated: 02/06/2022 5:26PM PST
What is this thing?
Wacky_Pathy
You can, but the truck won't pick up any power unless the valve was jammed wide open before. I've read that the EGR makes the engine idle a little better, but I've never tested this with mine. Unless it's hooped already, I'd leave it alone, mostly because the fittings on the pipe to the exhaust manifold are a real PITA to get loose.
