Need to trigger power locks?
maddmark1981
Ok guys things went winky, she started killing batteries, then power windows, locks and heater blower now no longer work. I can't find any fuse for these. I need help
Sent from my LG-H812 using Tapatalk
I looked at all my fuses in drivers side under dash and all are good. I have no clue as to where any other fuses might be.
It's so weird cause one thing after another keeps going.
I really want to keep her even though she's on 340,000KM
Fuse links are different from fuses. Fusible links are short pieces of wire that act as a fuse, they are designed to melt when over loaded to save the rest of the system. There are fusible links in the wires by the battery.
I'm not sure if you read through my recent thread where I was having some weird electrical issues.
Anyway, once you start the vehicle, push in on the key and move it around a bit. Just be careful so you don't engage the starter. I was having intermittent issues, no radio, ac, ect. I would wiggle the key, thing would come back on.
Rf600 has a good point. About the only things that are common to all of the issues you are having is the fusible links by the battery and the ignition cylinder.
Ok so you were right there was a wire that had melted. I got everything back except the power windows and locks. I'm trying to figure out for the life of me how to get my passenger door open. Or the window.
