r50chilkoot Posted December 20, 2016 Share Posted December 20, 2016 In my vehicle I have some mad belt squeak and its starting to get annoying. After a bit of research I determined that I don't have enough tension on the belts. Knowing this I looked under the hood and sure enough there pretty loose. I also noticed that there is not automatic belt tensioner's. So with this in mind, How can i adjust the tension on my belts? If anyone knows, that'd be helpful. Visual aids would also be helpful. Link to comment Share on other sites More sharing options...
hawairish Posted December 20, 2016 Share Posted December 20, 2016 http://www.nicoclub.com/manuals/Pathfinder/1998_Pathfinder/ma.pdf See MA-13. Concept is pretty simple: there's a bolt and a nut for each tensioning pulley (in your case, 2 idlers and 1 on the p/s pump). The bolt loosens or tightens the belt tension by moving the pulley, and the nut holds the pulley's position. The diagram shows you which nut to loosen, which bolt to turn, and where to measure for belt deflection. Link to comment Share on other sites More sharing options...
r50chilkoot Posted December 21, 2016 Author Share Posted December 21, 2016 thats helpful. thanks Link to comment Share on other sites More sharing options...
Kingman Posted December 31, 2016 Share Posted December 31, 2016 Do it all from underneath Link to comment Share on other sites More sharing options...
vagabond Posted January 9, 2017 Share Posted January 9, 2017 http://www.nicoclub.com/manuals/Pathfinder/1998_Pathfinder/ma.pdf See MA-13. Concept is pretty simple: there's a bolt and a nut for each tensioning pulley (in your case, 2 idlers and 1 on the p/s pump). The bolt loosens or tightens the belt tension by moving the pulley, and the nut holds the pulley's position. The diagram shows you which nut to loosen, which bolt to turn, and where to measure for belt deflection. and the alt has a bolt from the adjusting bracket to loosen then another bolt for the adjustment at the end of the bracket 14 and 12 mm if I remember correctly Link to comment Share on other sites More sharing options...
LittleFR Posted January 16, 2017 Share Posted January 16, 2017 And if your like me once you remove skid plate, do all that work... Get the belt to quit squeaking, a bearing will start squeaking. Haha. Link to comment Share on other sites More sharing options...
