genx Posted July 21, 2016 Share Posted July 21, 2016 Driving home from work smelled something burning from passenger side front seat , engine died hasn't started since . I know this isn't much to go on. could it be the ecu? is there a known problem with 94s . any help is appreciated I will give more detail as I check it out. I just don't want to buy un necessary parts. Thank you Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted July 21, 2016 Share Posted July 21, 2016 Remove the seat and open the cover of the economy and take a look to see what happened and assess the damage. Not a common issue and yours is the first I've heard of. Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 21, 2016 Share Posted July 21, 2016 I think I remember one other thread where a resistor or something burned out in the computer. Certainly not common though. I would take the cover off the computer and look for anything obviously burned. If it is burned out, I would be inspecting the harness for short circuits before putting a good ECU in its place. Link to comment Share on other sites More sharing options...
Terranovation Posted July 22, 2016 Share Posted July 22, 2016 You say it's smelling like burning from the passenger side so my guess is you have been running the a\c and that burnt leaves you can smell coming from the evap box. What happens is the resistor that is screwed onto that plastic box is clogged up with leaves, twigs etc that fall down into the front cowl vents. There is a way to clean it out, have a look in the how-to section. It's called Fire Prevention or something. Link to comment Share on other sites More sharing options...
k9sar Posted July 25, 2016 Share Posted July 25, 2016 I would think the blower resistor is causing it. Pretty common if you get crap in there. http://www.nissanpathfinders.net/forum/topic/7466-how-to-prevent-fire-clean-blower-resistors/ Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 25, 2016 Share Posted July 25, 2016 Not sure how burning pine needles in the HVAC would make the engine quit. Link to comment Share on other sites More sharing options...
k9sar Posted July 26, 2016 Share Posted July 26, 2016 (edited) lol. guess I should have read the original post. Missed the 'it died' part. I have not heard of an ECU burning up but I suppose it's possible. If you pull the seat and ECU cover, shove your nose there and sniff. If it fried, it will have a definite burnt smell and maybe even some melt indication on the cover or connectors. if this is the case, get the numbers off the ECU and post. I might still have a spare that I pulled form a junkyard. Don't think they are completely interchangeable so matching a model or part number would be best. (23710-85P##) Edited July 26, 2016 by k9sar Link to comment Share on other sites More sharing options...
